JoeMag's Avatar
Can I replacing case parimeter washers?
Well, just put my case back together (82 turbo) and it apprears i got a bum batch of case perimeter washers and they were not hardened. Nuts are really smashing them and I'm finding after few hours I can turn them a little at 18ft/lbs.
Can I replace washers one at a time with good ones??
Old 12-30-2005, 07:46 PM
Super Moderator
cstreit's Avatar
Are you sure you used the steel ones and not the aluminum ones?
Sure you can replace them... Just do them one at a time...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-31-2005, 08:19 AM
Irrationally exuberant
ChrisBennet's Avatar
I use steel washers and metal locknuts for the perimeter bolts. (3.0L and later aluminum case motors.) I'm not sure when I started seeing motors with these fasteners, may 3.2's or 964 motors.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-31-2005, 10:25 AM
JoeMag's Avatar
Well, after a night of thinking about this, I decided to not risk it and just split the case again... Clean up was much easier 2nd time around (3hrs to split and clean).
The alum washers were totally smashed. Many stuck on the stud. Going with stainless steel ones this time.
I used the sealant that Henry recommends for case perimeter (three bond 1104) and was very impressed with it. You could see a super thin layer of this all the way around the case. Interstingly enough the loctite 574? on the webs was not fully cured after 16 hours. Only place it was really cured was where it filled in the bearing tab space.
--Joe
Old 12-31-2005, 03:06 PM
Dadofour's Avatar
Joe,
Did you use Brake cleaner to remove the 1104? I found it liquified the 1104 and allowed it to be brushed loose with a wire brush.
Good luck with the next seal.
Than
Than
My Track Schedule
1984 911 Viper Green Track Car - Parted out to fund
1993 BMW 325is Spec E36 Race Car
Old 12-31-2005, 04:03 PM
JoeMag's Avatar
Actually used carb cleaner and scotchbrite pad.. came right off. i think that carb cleaner will just about disolve the metal...
Old 01-02-2006, 05:36 PM
