intermediate shaft cover stud depth
I have to reinstall my int shaft cover studs. Anyone know the length to leave protruding? I assume this is how its done, not by torque. Also, bluie locktite, right?
Thanks,
Brian
Old 01-15-2006, 02:36 PM
AFJuvat's Avatar
Not having an engine right in front of me to measure, a good rule of thumb is you want a few threads of the stud protruding above the nut when properly torqued with a spring washer.
Dry fit everything and see where it needs to be and adjust accordingly.
Use red loctite on engine case studs that you will not be removing later.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-15-2006, 07:52 PM
Spring washers or flat washers? The book doesn't specify, but I don't remember M6 sping washers being part of the hardware kit from pelican. Which other studs require spring washers (I used flat for the breather and the temp switch on top of the case).
-Brian
Old 01-16-2006, 01:18 PM
Super Moderator
cstreit's Avatar
The nuts are nylocks so either one is okay, but personally I think spring washers are a joke... Never use 'em...
Just checked a 2.4L case at 0.6"
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-16-2006, 01:50 PM
Thanks guys. Anyone use any kind of sealant on the paper gasket or install dry?
-Brian
Old 01-16-2006, 02:24 PM
