Jeff Alton's Avatar
Carb size question??
Just curious about carb size.... 3.4, 10.5, twin plug, 1 5/8 headers, ge40ish cams..... How much power am I giving up using 40's instead of 46's?? Car is dual purpose street/track so drivability is important too. Or are the 40's just way too small??
Cheers
www.turn3autosport.com
Old 02-08-2006, 09:16 PM
Jeff:
A 3.2 or 3.4 needs 46mm carbs. The venturi's can be sized for how you drive the car and what you like,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-08-2006, 10:34 PM
camgrinder's Avatar
If you want to shift past 6500 rpms, I would say 40's are too small.
John Dougherty
Dougherty Racing Cams
Jeff Alton's Avatar
Very well then! 46's it is then!
Cheers
Old 02-08-2006, 10:52 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I agree with all the preceding posters. One thing to remember is that you can change the butterflies on you 40 to 44 or 46 and end up with what you need at a reasonable price.
When choosing a carburetor for track use it's important to remember that Porsche never used a 40mm carburetor on anything larger than a 2.0 and that engine used a 46 with 42 mm venturies.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-09-2006, 05:14 AM
