Carb size question??
Just curious about carb size.... 3.4, 10.5, twin plug, 1 5/8 headers, ge40ish cams..... How much power am I giving up using 40's instead of 46's?? Car is dual purpose street/track so drivability is important too. Or are the 40's just way too small??
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jeff:
A 3.2 or 3.4 needs 46mm carbs. The venturi's can be sized for how you drive the car and what you like,.....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
If you want to shift past 6500 rpms, I would say 40's are too small.
John Dougherty Dougherty Racing Cams |
Very well then! 46's it is then!
Cheers
Author of "101 Projects"
40s are fine for a 3.0 or a stock 3.2 with carbs bolted on. Any increase in displacement beyond that, or a hotter cam will require the larger 46mm carbs...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Try not, Do or Do not
I agree with all the preceding posters. One thing to remember is that you can change the butterflies on you 40 to 44 or 46 and end up with what you need at a reasonable price.
When choosing a carburetor for track use it's important to remember that Porsche never used a 40mm carburetor on anything larger than a 2.0 and that engine used a 46 with 42 mm venturies.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
