Installing ARP head studs
When installing ARP head studs should I bottom them out in the case or adjust to 135 mm height to the top of the threaded portion ? I ask because it appears height is less important with the 12 point nut but just wondering if inserting to bottom of the case thread is preferred.
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 02-06-2006, 06:35 AM
3.4 Bigger is better
88-diamondblue's Avatar
The reason for the 135mm height is for use with the barrel nuts. With ARP or any of the premium studs you don't have to worry.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 02-06-2006, 05:38 PM
MBruns for President
JeremyD's Avatar
But I would bottom out in the case... be sure you run a tap in there first to clean up the threads.
Old 02-07-2006, 12:22 PM
David's Avatar
Rounded end up. Seems simple but I screwed it up at first. I learned from a loctite rep that loctite should be put in a blind hole not on the stud. If not the air in the hole prevents it from going into the hole.
Old 02-07-2006, 02:41 PM
I will bottom them out...also an interesting thought regarding putting the Loctite in the case hole.
Richard Lane
1978 911SC
Old 02-07-2006, 03:01 PM
Try not, Do or Do not
Henry Schmidt's Avatar
With our studs we use blue Loctite and run the stud all the way to the bottom. Then back it out a 1/4 turn. This takes unnecessary loan off the threads. The aluminum / magnesium will expand at a different rate than the stud material and we don't want the stud to damage the threads during that expansion.
This is specially true with mag case engines even when CaseSavers have been installed.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-09-2006, 05:38 AM
adomakin's Avatar
make sure you dont use the wrong tap if you want to use one. I used a tap that started removing more material from the thread in the case. horrible. I think a better thing to do would be to use an old head stud to run in and out a few times with some sort of solvent and lots of air, rather than a tap.
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 02-09-2006, 12:13 PM
1972_911T's Avatar
Thats what I did, old stud with lots of oil to lubricate the threads so as not to cause any damage then rinse out the oil with some solvent to ensure the new locktite sticks, the new studs screwed in by hand.
Old 02-09-2006, 06:52 PM
porschett's Avatar
Yes, don't use a standard tap. I also removed more than I liked. Do what 911T did as mentioned above.
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 02-09-2006, 08:43 PM
