Installing ARP head studs
When installing ARP head studs should I bottom them out in the case or adjust to 135 mm height to the top of the threaded portion ? I ask because it appears height is less important with the 12 point nut but just wondering if inserting to bottom of the case thread is preferred.
Richard Lane 1978 911SC 1973 "Clean" RS clone |
3.4 Bigger is better
The reason for the 135mm height is for use with the barrel nuts. With ARP or any of the premium studs you don't have to worry.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
MBruns for President
But I would bottom out in the case... be sure you run a tap in there first to clean up the threads.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Rounded end up. Seems simple but I screwed it up at first. I learned from a loctite rep that loctite should be put in a blind hole not on the stud. If not the air in the hole prevents it from going into the hole.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I will bottom them out...also an interesting thought regarding putting the Loctite in the case hole.
Try not, Do or Do not
With our studs we use blue Loctite and run the stud all the way to the bottom. Then back it out a 1/4 turn. This takes unnecessary loan off the threads. The aluminum / magnesium will expand at a different rate than the stud material and we don't want the stud to damage the threads during that expansion.
This is specially true with mag case engines even when CaseSavers have been installed.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
make sure you dont use the wrong tap if you want to use one. I used a tap that started removing more material from the thread in the case. horrible. I think a better thing to do would be to use an old head stud to run in and out a few times with some sort of solvent and lots of air, rather than a tap.
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Thats what I did, old stud with lots of oil to lubricate the threads so as not to cause any damage then rinse out the oil with some solvent to ensure the new locktite sticks, the new studs screwed in by hand.
Steve |
Yes, don't use a standard tap. I also removed more than I liked. Do what 911T did as mentioned above.
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy |
