strep's Avatar
[][][] Anyone [][][]
Engine Stand Adapter Ring I can borrow or buy. I am in los angeles. I can give deposit if you wish. Please let me know.
Old 02-07-2006, 08:31 AM
AFJuvat's Avatar
If you have a traditional engine stand with the 4 arms, you can use that on the engine - you just use the 4 transmission bolts.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-07-2006, 05:13 PM
strep's Avatar
do I need to pull off the clutch and pressure plate first
Old 02-07-2006, 05:16 PM
Irrationally exuberant
ChrisBennet's Avatar
AFJ
I know people have done it (Motor Meister does I think) but it just gives me the creeps. I don't think some 4 arms stands will not even allow you to attach all 4 arms to a 911 - the arms might be too long.
Also, if you want to split the case on the stand, you need the yoke or yoke adapter because it will support the motor safely using only one half of the case.
If worst comes to worst you can buy a yoke and sell it for $50 less than you paid when you are done.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-07-2006, 07:12 PM
len911's Avatar
I have use the good old American engine stand for 2 rebuilds and currentlly on my third. Never had a problem. I have cut 2 washers (per stud) in a moon like fashion (to clear ridges) to actually spread the load of the engine support into the face of the block and not on the ridges. See enclosed picture... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 02-08-2006, 04:03 AM
You talkin' to me?
chancecasey's Avatar
I did the exact same thing - using large nuts that I ground to fit around the ring on the case, and some extra nuts and washers. Takes a little thinking to get those arms arranged just right - I think I did mine a little differently than in your pic.
'Da book of course says use the adapter or risk tweaking the case - but my machinist verified my case was ok. Then again, mine is a 3.6L aluminum case - can't speak for earlier potentially weaker ones.
-Chance
'90 C2 Cab - Temporarily out of service
Old 02-08-2006, 12:45 PM
porschett's Avatar
I got one you're welcome to use. I'm in SD if you're ever headed down this way. David 858-337-7529
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 02-09-2006, 07:47 PM
