Supercharging a 2.7 engine
Helo
Can anyone on this forum give me some detailed info for supercharging a 2.7 engine. What kind of cilinders, pistons, inlet openings,cams,...turbo??,....etc. All info is welcome My personal e-mail adres: bart_elsen@jabil.com Thanks in advantage Regards Bart |
First thing, make a budget, Then plan your build, including inspection machine shop/parts pre/wip measuring.
I know there are kits you can install/update, eg http://www.goingsuperfast.com/ Know you will spend what you can buy a 930 for. Good luck.
Bernard |
Try not, Do or Do not
First piece of advise is to start with a 3.0 instead of a 2.7. It is hard enough to keep a normally aspirated 2.7 together let alone adding the increased pressures of a supercharger.
The mag case will freak out from the extra heat and cylinder pressures.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Hello Henry Schmidt
I sent you a Pm woud you tell me (or anybody else) if a CIS 2.7Head would fit a stock euro carrera engine ? best regards Philippe |
