GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Break In Procedure.. Your way?
Ive recently rebuilt the top end (rings, honing, heads...) on my 2.4. Im wondering if I've got it right for breakin procedure
Since I only have new rings and honing: (no new cams)
Use Non synthetic oil for breakin... 10w30 is what I normally run Or should I begin running Different weight oil?
1 Drive the car to operating temp
2 Accelerate liberally not to exceed WHAT RPM? app. 4000??
3 Decelerate allowing the cars momentum to continue pushing the engine
All the while maintaning regular operating temp.
Do these simple steps for the 1st 500 miles THEN
Change Oil
4 Continue w/ the same procedure for the next 500 miles maybe increasing rpm's a bit.
Good enough??
Old 05-05-2006, 02:12 PM
stevepaa's Avatar
I warmed mine for 20 minutes at the driveway, then drained oil and replaced oil and filter. Then warmed again and then drove it hard.
Find some hills if you can, and hard on the gas up and no gas down.
Did about 100 miles and changed oil again. Went 500 and changed oil again.
good luck
steve
old rocket inguneer
Old 05-05-2006, 03:30 PM
read the other break-in thread going on now
engine break - in - am I paranoid?? Mist from oil tank at idle
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-05-2006, 04:11 PM
mppickett's Avatar
good luck
This is close to what I did. I used 20W-50 dino oi:
1. warmed up by driving lightly and then drve for 20 miles hard on the gas and then no gas at all (rev up wind down against engine compression). I stayed out of boost but ran it up to 6000 rpm on the rev ups. After 20 miles of this I changed the oil and filter.
2. next 100 miles lots of rev up and wind downs. Small amounts of boost (no more than .3 bar). Didn't take it over 6000 rpm. Changed oil and filter.
3. next 500 miles. just like #2. Changed oil and filter.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 05-05-2006, 04:55 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I followed a guide used by some motorcycle engine builders. After a rebuild they will use the on off throttle method. Basically hard on throttle, but if you've rebuilt the valve train at all don't exceed any high revs. Once you've reached your comfortable max rev, let off the throttle and let the motor decelerate the car. The theory is that you load the rings hard, then when you let off the vacumm created during the exhuast stroke will suck any tiny bits out. This is supposed to give a solid build with tight sealing between the wall and rings.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 05-05-2006, 09:16 PM
Jeff Alton's Avatar
Lifting off throttle also puts pressure on both sides of the rings. The motor needs to see some load. I too use the methods from that motorcylce tuner.
Cheers
www.turn3autosport.com
Old 05-06-2006, 08:03 AM
GotaT's Avatar
Perfect.. Thats what I've been seeming to do, Now, I have noticed in my rearview at night smoke exiting the ehxaust pipe while on throttle... Is this normal or not?.. did your car do this?
I find its hard to leave the car below the 32 to 3500 mark while just normally driving.
... BTW my car has a NA 2.4l 72 engine
Old 05-09-2006, 06:49 PM
1fastredsc's Avatar
Carbs might need adjustment.
2007 Mazda 3 hatch
Old 05-09-2006, 10:26 PM
GotaT's Avatar
Im pretty sure carbs do need adjustment. The car has a dead spot around 28 to 3000 rpms. Feels like its getting fuel then not and back and forth at these rpms. ... One note. I noticed that once the car is fully warmed up no smoke was coming from the exhaust pipe when on throttle and the engine Really quietened down as far as chain and rocker noise. sounds great.. I hope that once it is completely broken in it sounds this good even at startup. think so?
Old 05-11-2006, 12:18 PM
1fastredsc's Avatar
I'm not sure, that's a subjective opinion. The general consensus though is that when a cold air cooled engine starts because of it's larger clearances, it's supposed to be noisy, rebuilt or not. I guess it's your call.
2007 Mazda 3 hatch
Old 05-11-2006, 06:07 PM
