DB_NC_95C2's Avatar
question re: 3.0L 'piston kit'
Does anyone know of a kit (don't know if it was OEM or not) to upgrade the 3.0L to higher compression and slightly larger displacement ? I was talking to a fellow today who knew a guy who did that upgrade (when it was time for rebuild) and it significantly woke up the engine.
Thanks.
'95 Porsche 993 Carrera, DACH-X, DACH-R, PSS10,RS Speedlines,RS StrutBrace, GT3TEK 993RS Aero
'06 Mini Cooper (O.Z,MTH, Milltek, M7)
http://www.hakkinen.com/spain99-mh1st-easy.mp3
Old 05-22-2006, 06:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Short stroke 3.2 kit.
Mahle makes one and so do we.
70.4 mm crank and 98 mm bore.
any comp. ratio you want.
PM me for price.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-22-2006, 07:56 PM
Super Moderator
cstreit's Avatar
The 98mm pistons (as recommended by Henry) are the only displacement upgrade you can do without machining the case.
You can also use LNEngineering cylinders and J&E pistons. I'm using that setup now (albeit with 100mm versions for 3.3L)
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-23-2006, 09:01 AM
