My friend Peter Booth at https://www.motorscience.co.nz can help you invert your Photo and your car.
regards |
Benny Hill used to have a segment on his show from the U.K. that went "and now from Austraila)
and they would invert the camera. regards |
We chose Dow 55 because of it's military application (testing and continued use). We buy it as military surplus because when we started using it, Dow 55 was not available in retail packaging. |
I think I missed it, but does anyone know how fast 1184 cures?
I am wondering if I should apply the 574 on saddles first or the 1184 on the perimeter first? TIA, Jim |
I think I did 574 first. The 1184 skims over pretty fast. Sent from my iPhone using Tapatalk |
Thank you sirs :-)
BTW, how does one keep the 1184 from squeezing into the case? I did a couple of test runs and boy the 1184 really squeezes out allot. I am not wrried about the 574 but do worry about silicon getting inside the case. |
Wtd
Noticed the case thru holes only have chamfers on nut side No wonder the old orings were crushed and ripped on one side Should I chamfer the Bolt side? |
Check the washers, as I remember half of them should have a chamfer and those go on the side of the case without a chamfer and the others should be flat?
Chamfer the holes. Use chamfered washers. Orings will be happy
Thank you Brothers
Yes all the washers are chamfered type Will be chamfering/deburring the d-side case thru holes Using this type of tool http://www.noga.com/pdfFiles/coun.pdf |
"BTW, how does one keep the 1184 from squeezing into the case? I did a couple of test runs and boy the 1184 really squeezes out allot.
I am not wrried about the 574 but do worry about silicon getting inside the case. " You just need a very thin coat but you want some squeeze out. The 1184 is not silicone RTV and it is semi-hardening and remains elastic so it doesn't break off like the silicone RTV does. It's the same stuff used to seal motorcycle cases, also sold as Hondabond 4, Yamabond, Suzukibond 4, etc. it's good stuff. |
One more, is it okay to have the 574 and 1184 contact each other, like bottom of the #1 and top of #7 bearing areas? TIA, Jim |
That won't hurt anything.
Throttle Body to Intake, SEALANT or DRY?
Hey Fellas,
Besides using the new back O-ring in the Wrigtwood Kit, I assume no sealant but just want to make sure. Does anyone happen to know the torque specs for the four allen bolts TIA, Jim |
Answered my own question:
No sealant just new O-ring :D Torque Specs, anyone anyone? |
| All times are GMT -8. The time now is 04:28 AM. |
