for the record, I bought Curil-T on Amazon delivered to CA no problem.
Try not, Do or Do not
There are carburetor cleaners sold on Amazon that clearly state "Not for sale in California" that regularly get shipped to California. Now, try to buy a toilet with a 2 gal tank....forget about it ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Banned
One builder suggested using black Permatex silicon on the thru bolt blue seals. Any thoughts?
In my next most perfect life somebody is going to put a chart together grouping all these products keyed to Waynes bible. __________________ |
Banned
I wonder why Wayne's rebuild book says to spread it on the right side? On page 133 it shows a picture with the sealant applied - side mounted to engine stand with studs in it.
Is there are reason he specifies it this way? Also, how do you know how the factory did it? (not being a jerk - just curious) |
Simple answer: the author and his advisers were not professional engine builders with Porsche 911 expertise.
^^^^ this....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Just got this from Admins ref a response I made to a for sale ad by a known Pelican; “Boxster Brake kit F/R the seller is not always active on the forums but you contact the him at deyecrest@gmail.com if youre still interested”
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold Last edited by H-viken; 11-06-2022 at 12:12 PM.. |
Yes, Have noted him as a TROLL...
I'm a new registered member and inquired on a set of wheels. I got the same PM from Admins referring me to deyecrest@gmail.com |
Forced Induction Junkie
To add a bit more detail to the scammer's MO.......
Go to the top of this page and then the pull-down Menu " Search this thread". Put "Black" as the word in your search. Interesting what shows up as the very first post 06-29-2008 concerning Black Silicon.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Imagine if these people put as much effort into doing something legitimate as they do to running scams, they just might make a difference in this world. |
More than likely a probing attempt to get in through the backdoor of Pelican or an attempt to see if a phishing scheme could be generated to attack individual Pelican subscribers.
Banned
There's a Dow sealant for O-rings, Henry Schmidt offers it for sale, along with the others noted here. Also, Viton (green) versions of these are the ones to use.
Mods, adminss is a Bot. Please Ban.
Post #42 from this thread. Bot, please ban. |
Driver's License Owner
New build and I have a very small leak at one of the top through bolts (nut side) at #4 and a heavier leak at #5. No other issues. I used Dow Corning 111 and green viton o-rings during assembly. I want to reinstall new orings but am wondering if I should try a new sealant, such as Permatex RTV Wayne mentions in his book. Maybe there was a small scratch or something that requires additional sealing properties. Thoughts?
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I'm in the NO RTV in a flat 6 camp. It's one of Satan's bodily fluids.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
To date I have never had one of the through bolt o rings leak. It sounds like you could have one of a few things going in: - when tightening, the washer rotated and cut the o ring. - when the o ring was installed over the threads, it was cut - the underside of the washer might have debris from previous build that was not cleaned. - case spigot surface is compromised, not flat, or has debris remaining from prior build. Sorry this has happened to you. But looks like you gotta pull it all out to double check.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
"the Watson"
Top or Bottom studs? If top, you should be able to get access by removing alternator and releasing the tin deflector. Replace o-rings, and re torque. If bottom bolts, you have more work to do... NO to RTV..... Cheers
