I have the Curil T and Loctite 574 already, but came across this thread and thought since I haven't assembled the motor yet I might as well take the advice of the experts in this thread. Well, maybe not all the "experts"... |
DustoffDriver
Same list as previously posted by others, except I added the return tube o-ring lubricant as recommended in one of Henry Schmidt’s previous posts.
Outer Case Halves: Threebond 1104 (now 1184) Bearing Saddle Surfaces: Loctite 574 #8 Bearing (balancer end) O-Ring: Threebond 1211 (now 1215) Case Thru Bolts: Dow Corning 111 on Green Viton O-Rings Flywheel Seal: DRY Balancer Seal: DRY Intermediate Shaft Cover to Case: ThreeBond 1211 (now 1215) Oil Breather Cover to Case: ThreeBond 1211 (now 1215) Cylinders to Case: Curil K-2 or ThreeBond 1211 (now 1215) Cam Towers to Cylinder Heads: Threebond 1104 (now 1184) Cam Chain Housings to Case: Threebond 1104 (now 1184) Cam Chain Housings to Cam Towers: Threebond 1104 (now 1184) Cam Chain Housing Cover to Cam Chain Housing: Threebond 1104 (now 1184) Gaskets: Thin coat of Loctite 574 Oil return tube O-rings: Dow 55 o-ring lubricant (alternate: Dow 111). |
I've found an alternative to Threebond 1184 which is Aisin AB1184A. MSDS sheet says its made by Threebond, so should be good there. Question is, for the areas that call for 1211 or 1215, is 1207 or 1281 a viable alternative, or do I just use the Curil T that I already have? Both the 1207 and 1281 are readily available as they are the Aisin brand manufactured by Threebond. |
Looks like 1207 might work, except that its tack free in 3 minutes vs. 40 for the 1211. 1215 has a 20 minute tack free time.
The other difference is that the 1211 and 1215 are Oxime solvent, 1207 is Acetone. First preference would be to use the exact products recommended, but as I mentioned, Threebond is currently unavailable in Canada, so need to look for the rebranded equivalents. |
![]() Many thanks
Keith - Calgary 1969 912R (911 engine) - Blutorange |
Forced Induction Junkie
I've used a light coating of Curil-T on both sides. Keeps the gasket in place during assembly and prevents weeping during engine heat cycles.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Schleprock
The point of using the sealant on the paper gasket is not only to give it some additional sealing ability but also to give the gasket some wiggle room to settle in place as you’re physically assembling the parts. This paper gasket can sometimes get pinched as you’re pushing the cover plate (actually called a thrust plate because the end of the camshaft can push against it during engine operation) home into the chain housing. So you definitely want to look around/behind the chain housing after installation to make sure the gasket didn’t get pinched or folded upon screwing down the thrust plate.
People have also recommended other sealants on this paper gasket like Permatex copper spray, Curil T green goop, and the famous Loctite 574 orange goop. Whatever works. Just don’t use silicone sealant, PLEASE! Again, the purpose is additional protection against a leak. I don’t like anything too sticky because sticky makes it more likely for the gasket to get stuck in a bad position. You want the gasket to have a little bit of ability to settle into place. But of course you don’t want it to squish out of place either! I have personally encountered this leak on one of my engine projects and it’s a big disappointment to have. It’s a lot of work to correct the leak and therefore you absolutely want to avoid it happening My opinion is the gasket is supposed to be fine without sealant. That’s the whole point of the gasket- to seal. The challenge here is that the “snout” on the end of the camshaft housing is not always fully flat. I have leveled the snout on several cam housings via a flat plate and wet sandpaper which has shown me some spots on the snout are very narrowly flat with the rest of the surface. Therein lies the problem and I feel the problem should be addressed at the sealing surface to ensure the best seal. Just my opinion and to each his own, as the saying goes It’s very easy to level the snout surface. All you need is a good flat surface, some tape, some wet sanding paper (400 or 600 is fine, no need to make it super smooth) and a sharpie marker to color the snout for use as an indicator of your sanding progress. You’ll see right away how flat, or not, is the snout after just a few swipes of the snout across the paper.
Kevin L '86 Carrera "Larry" |
I'm having difficulty locating Curil T.
However, I see Curil T2 is commonly available. Is Curil T2 replacing Curil T?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Racer
To quote: "Its [sic] called CURIL T2 and this name replaces the old designation of Curil K2 and Curil T sealants."
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I could have missed it, but any sealant recommended on the gaskets for the chain tensioner covers?
A very light tacky coat of Curil-T works quite well. Just enough to make the gasket look shiny is all it takes.
Just another set of data points from my recent 3.2 to 3.4 rebuild. Grateful for all the good information on this thread and to no longer have any oil on my garage floor.
Sealants: Case perimeter: Threebond 1184 Case webs: Loctite 574 Through bolt o-rings: Molykote + tiny amount of Hondabond 4 on washers #8 Bearing: Threebond 1211 Cylinder base shims: Curil-T Heads to cam towers: Threebond 1184 Oil breather gasket: Hondabond 4 Chain housing to heads: PFTE grease on o-Ring, Hondabond 4 on gasket Chain cover to case gaskets: light Hondabond 4 Chain cover gaskets: dry Oil return tube o-rings: Molykote Int Shaft cover gasket: Hondabond 4 failed, switched to Loctite 574 with new gasket. Rear Main seal: Installed dry outer edge, light PTFE grease on inner to prevent burning on initial startup. Leaks and fixes (none of the leaks were enough to even cause a drop on the floor):
(new on right) ![]() ![]() ![]() Last edited by thetorch; 10-29-2022 at 11:55 AM.. Reason: typo |
Member 911 Anonymous
Outstanding, enjoy your New 3.4L, she will feel 700 lbs lighter :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks for the excellent update @thetorch
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
Try not, Do or Do not
Curil T and Curil T2 are different formulas. T2 is higher temperature and lower viscosity.
We still use the "T" because it seems to stay in place better and temperature resistance is more than adequate. Many new products offered by manufactures as "new and improved" are in fact just environmentally compliant. 1104 was replaced because of lead content not performance enhancements. Curil "T" was replaced to eliminate "undesirable solvents". I guess they could have kept it with a Millennial safety warning "not for human consumption". Maybe much like Tide pods.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-01-2022 at 03:22 PM.. |
I much prefer to use T, but seems impossible to find...
Try Amazon. Shipping may be an issue. Many of the products we prefer to use are not California EPA compliant.
https://www.amazon.com/Elring-non-hardening-temperature-resistant-sealing-compound/dp/B01N0X8M8G/ref=sr_1_1?crid=2K0ITTVX7SRX1&keywords=curil+t&qid=1667344977&qu=eyJxc2MiOiIwLjc5IiwicXNhIjoiMC40OCIsInFzcCI6IjA uNTEifQ%3D%3D&sprefix=%2Caps%2C198&sr=8-1
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
item got stuck in post in poland.. she said she would refund... never did... too much time had passed and I was not eligible for refund.
