Send a message via AIM to Purkinjefibre
3.2 SS Engine update
Hi Guys, found the time to close my beautiful crank inside it's new home. Everything seemed to come together OK, i got the Loctite 574 to spooge out nicely- crank moves smoothly. I was a bit frantic, trying to get everything done in 45 mins and then i realised my through bolts are round the opposite way To Wayne's book. Is this a problem? Also my compression ratio is 10.3 with .75mm cylinder base gaskets, i am looking to get 10.0:1- can i use 1mm? how does this affect chain housing/cam sealing?
thanks
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 06-12-2006, 07:59 AM
resident samsquamch
sand_man's Avatar
Actually, that is the correct way (from the factory). My engine had never been apart before and I have pictures clearly showing the through-bolt acorn nuts on the drivers side (before I split the case). The only acorn nuts that weren't were the ones located behind the egine oil cooler (they obviously have to be on the passenger side). In Wayne's book, he has the acorn nuts all on the same side...the passenger side of the case. I got worried about this, but others told me that it doesn't make any difference.
-jeff
Old 06-12-2006, 08:07 AM
That's a relief
Thanks Sand_man. That is good to know, i didn't take my 3.0 apart so never saw it Factory style,
cheers
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 06-12-2006, 08:18 AM
3 restos WIP = psycho
kenikh's Avatar
First, what is your measured deck height? Are you planning on using twin plug ignition? Isn't this a 98mm P/C engine? Even 10:1 on pistons that big is dangerous.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-12-2006, 09:37 AM
Compression ratio
Hi Kenik, yes this is 98mm and will have twin plugs. Deck height is 0.0475. These pistons are a little more radical than i thought. Can i try 1mm's worth of shims?
cheers
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 06-12-2006, 09:56 AM
kenikh's Avatar
Why not just keep the CR at 10.3:1? Twin plugs make that eminently doable, especially with hot cams. If you really want to do this, I seem to recall 1mm shims are fine, but have never done this myself. I believe Henry Schmidt said that is about the maximum you should use, but I won't speak for him. Perhaps he'll come along and confirm or deny this...
Can you post pics of the pistons?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-12-2006, 09:59 AM
10.3:1
Thanks Kenik, I might just do that. I thought that the West Coasters would be awake for by now. Henry are you there?
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 06-12-2006, 10:02 AM
Irrationally exuberant
ChrisBennet's Avatar
Re: Compression ratio
cheers
Brett
Your deck height (1.2mm) is already higher than ideal (but similar to what I've seen on a 964 motor) so I wouldn't increase the deck height. Increasing the deck height will reduce the compression some but it will increase the tendency to knock (pre-ignite).
I've machined JE 98mm 10.5:1 pistons down to 9.5:1. I'd go that route rather than using a thicker base shim.
I hope I'm wrong, but it looks like you've got a lot of squezed out 574. The last time I put it on that thick the case leaked...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-12-2006, 05:50 PM
Party Member
viejopatron's Avatar
"The last time I put it on that thick the case leaked... "
Jeez, Chris, make us DIY'er feel confident.
However, I can't resist. Please tell the story re: thick goo = case leak.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 06-12-2006, 06:06 PM
Re: Re: Compression ratio
-Chris
Chris,
I'm curious to know how lowering the compression by raising the deck height could increase the tendency to detonate. I could see this possibly in an engine with a squish area that needs to be carefully maintained but that is not the case here.
regards,
Phil
Old 06-12-2006, 08:51 PM
kenikh's Avatar
Everything I've read says squish IS imprtant int ehse engines. Because of the pent domes, I can see errant gases hanfing out in the outer regions of the combsution chamber just waititng to ping...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-12-2006, 10:14 PM
Re: Re: Re: Compression ratio
Originally posted by tctnd
Chris,
regards,
Phil
As it was explained to me, ideally you want between 35 and 40 thousands (.035-.040" / .89-1.01mm) deck height. A larger deck height leaves a "pocket" out at the edge of the piston that can increase the chances of predetonation.
-Chris
Old 06-13-2006, 03:31 AM
It was back in 2001. Back then all I had was had Bruce Anderson's book and the factory manual to go on.
In my ignorance I (incorrectly) thought:
A: "If a little 574 is good, more is better"
B: "Better torque those important though bolts first, then the perimeter bolts"
Here are the truths:
Wrong: 574 should be put on thin - like suntan lotion. Remember, if the case is prepped right it will almost seal without sealant.
Wrong: As soon as you put the case halves together snug up the perimeter bolts and get the sealant squeezed out before it skims making it impossible to tighten properly. Loctite's spec sheet for 574 states "Flanges should be tightened as soon as possible after assembly to avoid shimming." I will forever grateful to Steve Weiner for telling me this trick.
-Chris
Old 06-13-2006, 04:06 AM
David's Avatar
I used Copper Coat on my base gaskets, I haven't run it yet but I heard good things about the stuff.
I agree on not increasing the squish any more than it is. What cams are you running?
Old 06-13-2006, 05:16 AM
resident samsquamch
sand_man's Avatar
I can't really comment on the deck height and squish stuff (I let my machinist, Neil Harvey measure and deal with those aspects), but when I first saw the pictures, it did look like the 574 was a bit thick! Maybe it's just a photo thing. I used the ThreeBond 1104 on mine. Keep in mind that what you see squeezing out of the outside case perimeter is often squeezing on the inside!!!! I guess this 574 stuff can be "washed" away inside with the oil flow, but I sure couldn't/wouldn't gamble with it.
I went VERY, VERY thin with 1104 and had hardly any squeeze-out. I also tightened my perimeter nuts first, then did the through-bolts.
Please don't misunderstand, I'm by no means attempting to cause you worry...I agonized over the case sealing like a lunatic before I finally jumped in. Just be aware, that's all!
-jeff
Old 06-13-2006, 07:18 AM
will it leak?
Hi guys, all of your input is appreciated. First off those images are close ups. I tried putting the sealant on as a smooth layer all around as fast as possible. It actually looked similar to the pic in Wayne's book page 133. I had it together within 30 minutes and i don't think the 574 was skinning at all. With hindsight i probably could have used less- but it didn't spooge out until being properly torqued up.
I will certainly let everyone know it it leaks or not.
Easy
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 06-13-2006, 08:47 AM
Wink engine update
Hi all lots of progress to report. P and C's are in place and cam housings on. I'll start with some pics...
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 01-19-2007, 01:59 PM
cams are in too
cams are in and timed...
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 01-19-2007, 02:01 PM
Looks nice. I hope those mechanical chain tensioners are just for setting cam timing.
Old 02-17-2007, 03:23 PM
abit off center
cgarr's Avatar
Looks very nice!! One case half has a chanfer at the thru bolt, this is the side the nut goes on, (helps seal around the bolt thread) I put mine all in and tite without the o-rings then removed one at a time and put the o-rings on each, old 912 engine trick to keep the o-rings from grinding up when going tite, mine were also opposite the cooler too.
______________________
Craig
G2Performance
Old 02-17-2007, 03:48 PM
