Cylinders
Does anyone know anything about these cylinders?
Sorry if this is a rerun. I'm not building, just curious.
From an Ebay ad.
http://cgi.ebay.com/ebaymotors/Porsche-911-84mm-Aluminum-Nikasil-Cylinders_W0QQitemZ8074549673QQcategoryZ33617QQrdZ 1QQcmdZViewItem
JPIII
Early Boxster
Old 06-18-2006, 12:41 PM
QSC is the manufacturer. There has been a ton of these on the market lately.
Sorry I don't know of anyone currently using these.
Old 06-18-2006, 12:43 PM
I think Henry from Supertec is selling these and probaly has a some experience with them maybe he can speak for them.
Old 06-18-2006, 12:50 PM
3 restos WIP = psycho
kenikh's Avatar
Are you sure these are the same as Henry's?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-18-2006, 01:50 PM
I would think so since Henry has been selling QSC branded cylinders on ebay as well for some time now.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 06-18-2006, 02:02 PM
JP,
I've been looking at the QSC's with the JE pistons for my 2.7 project as well.
Let me know what you find...
Thanks,
Bill P.
Bill Pickering
1974 914-6 2.7...aka...The Beast
1997 Boxster 2.5 track car...aka...Lucille
Old 06-18-2006, 04:24 PM
They may be fine. Especially if Henry sells them.
For me personally the 9.5 compression cylinders are interesting.
I think I'll hold out for the 10:1 cylinders.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 06-18-2006, 09:30 PM
kenikh's Avatar
Since when do cylinders have anything to do with compression? I am sure height group can affect CR, but in the end it is still calculated from piston and head volune...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-18-2006, 09:33 PM
Kenik,
Duh!
More High tech from Ebay.
DOUG
Old 06-18-2006, 09:41 PM
Wayne:
Are they spun cast (centrafugicaly..sp?) like Mahle?.....the pic make them appear to be cast.
JPIII
Early Boxster
Old 06-19-2006, 11:15 AM
kenikh's Avatar
They are indeed cast, especially if they are the same as Henry's. He and I talked quite a while back and he said they are cast to cut down on cost (apparently with no detriment to quality). I believe that the only machined billet cylinders on the market are Charles' Nickies, while Mike Bruns iron/aluminum cylinders are machined from billet with pressed in iron sleeves.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-19-2006, 11:20 AM
The only cylinders that are spun cast are the factory cylinders and the Perfect Bore branded cylinders. If I am not mistaken, Mike's sleeves are spun cast too and are ductile iron, not cast iron.
Charles Navarro
Old 06-19-2006, 11:30 AM
Author of "101 Projects"
Wayne 962's Avatar
Originally posted by J P Stein
Wayne:
Again, I have limited knowledge of these units at this time...
-Wayne
Old 06-19-2006, 11:23 PM
resident samsquamch
sand_man's Avatar
I'm running Henry's Ps&Cs on my 930. 98MM (3.4L) with 7.3:1 CR. I'm still well within the break-in period on my engine, but so far so good. No issues. Time will tell.
-jeff
Old 06-20-2006, 05:54 AM
bavaria911's Avatar
I started a thread about 2 weeks ago -
New 2.4E P&Cs
Are these the same company /seller we are taling about?
Bavaria911
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 06-20-2006, 06:47 AM
Close, but not the same. AA is another manufacturer from China, but they have been around for a few years and are now venturing into other markets. Their focus is on cast iron cylinders and high silicon cast pistons, although they do now have limited forgings for the vw side of their operations.
Charles Navarro
Old 06-20-2006, 06:51 AM
Super Moderator
cstreit's Avatar
How can they give you the compression ratio from JUST the cylinders?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-20-2006, 09:03 AM
Maybe their director of sales was taught by motor meister
1983 911SC
1977 911S "parting out"
Old 06-20-2006, 12:20 PM
Even Motor Meister knows better than that.
And I don't like MM either. They fu*&ed up my son's transmission and would not stand behind it.
Doesn't look good for this Ebay seller.
DOUG
Old 06-20-2006, 06:22 PM
