gungadin's Avatar
engine # *6392956 someone?
This is in a '76S
My dads old car. Once a bad leaker but now dry???
Old 07-14-2006, 01:23 AM
Old Member
Looks like a '69S.
Clifton Brown
https://www.mancalamarketing.com
Old 07-14-2006, 08:09 AM
... or a '79 3.0 SC - Porsche in their wisdom used this same series of engine numbers for both years !
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 07-14-2006, 09:24 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Installed in a 76 car and no oil leaks I'd guess 1979 3.0.
Is it mag or aluminum?
We could use the designation number (930/??) to be certain.
This number is located on the engine case on the right side of the fan housing.
Case casting number will also tell us which one you have.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-14-2006, 10:29 AM
gungadin's Avatar
That number looks like 930-OS
Does that make it magnesium or aluminum?
Still a '79 3.0L?
Old 07-15-2006, 08:45 AM
79 911 SC 3.0. Aluminum
This is a very nice up grade for a mid 70s 911.
Henry Schmidt
Ph: 760-728-3062
Old 07-15-2006, 09:09 AM
More than likely 930/03 - that would concur with it being a '79 SC engine (aluminium crankcases).
930/05 is a Japanese-spec '79 SC engine (serial number would be 619XXXX).
930/06 is a California-spec version with serial number in the form: 659XXXX
Andy
Old 07-15-2006, 09:10 AM
gungadin's Avatar
YOO DA Men!
laquer thinner/toothbrush....it is a "3"
Thanks so much for your help.
Old 07-15-2006, 01:21 PM
Author of "101 Projects"
Wayne 962's Avatar
I'm a huge fan of 1974-77 cars with an upgraded engine. These cars are so neglected and unwanted by the Porsche community for their 2.7 engine problems, that you rarely see too many these days. Installing a 3.0 solves 95% of the engine problems (replace head studs and install Carrera chain tensioners while you're at it), and really makes these narrow body cars sought after.
-Wayne
Old 07-16-2006, 11:46 PM
