flatsixcrazy's Avatar
Looking for a shop to modify 3.0L rods
Hi All,
I am looking for a shop that can modify my 3.0L rods to be used with 3.2L P&Cs and 3.0L case and cranks. Please make a recommendation of the shops you know that does it?. Thanks for all your help. Andy
Old 08-29-2006, 10:10 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: Looking for a shop to modify 3.0L rods
Originally posted by flatsixcrazy
Hi All,
Ollie's in Santa Ana, CA is a well-known Porsche exclusive machine shop that does many of the sublet work for the local SoCal shops (including some for PMNA) and also from other parts of the country. They can perform this service for you. I have an old price list from Ollie's, I think to simply go from a 22mm pin diameter to 23mm pin diameter is roughly $100-$150 for the set.
Henry from Supertec can also do this for you. He is a frequent poster here touting his products and services while also giving advice/recommendations, you can easily find him by searching...
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 08-29-2006, 02:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The conversion takes resizing the bushing from 22mm to 23 mm and you must also offset the bushing.
The result is a lightly longer rod and with most Porsche engines the longer rod is a plus.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-29-2006, 04:07 PM
