With the Mahle P+C's, as long as the compression is kept down, as long as the boost was very mild and in check with sufficient IC and fuel, I wouldn't be worried. The other issue with the 100mm bore is that IMHO there isn't sufficient sealing "real estate" to flame ring w/o sacrificing integrity, especially with the Mahle cylinders being cast.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Thanks for the info. I'm currently using an Andial IC, but I'm looking for a DP full bay IC.
Harold
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
He did say that the Carrera 3.2 intake can't be fixed to flow the way he wants it to, so you have to go with the 964 unit......or maybe ITB's if you are really crazy.......lol
1985 M491 Carrera Slate Blue Metallic(fun car) 2001 BMW 325i (basic tranportation) http://jmforge.com Last edited by jdm61; 10-07-2006 at 12:11 PM.. |
