Banned
Clean the area around the fitting before you remove it so you don't deposit anything in there while you are replacing the fitting.
Old 03-30-2025, 01:20 AM
Has anyone using the restrictors noticed more oil leaks around the engine from higher oil pressure?
I'm not picking my nose..I'm porting my upper intake manifold.
Old 03-30-2025, 03:18 PM
It's a 914 ...
stownsen914's Avatar
I'd understood that the higher oil pressure achieved is mostly at idle and lower RPMs, where oil pressure is low anyway. Did you put restrictors and notice more leaks?
Old 03-31-2025, 05:02 AM
Yes.
Old 03-31-2025, 11:49 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We were making our own cam feed control fittings a decade before Porsche introduced them in the 965.
We have never seen a connection between reduced oil flow to the top end and new oil leaks.
What you are probably seeing is correlation without causation.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-31-2025, 05:37 PM
