OCD project capitan
Just picked up parts to build a 2.6 engine
Hello eveyone, (edited)
I just picked up a lump sum of 10+ year old parts sitting in a rotting shed, and heres the parts: 73 E heads, 32mm intake, 33 exhaust 73 case 73 distributor 73 911 E case, crank and rods. RSR 92mm Mahle pistons and cylinders Later factory race cams (4 bearing surfaces) with a 908 grind, part # 911.105.137/138. 0R 911E Bosche MFI system Besides the obvious shuffle pinning and oil bypass upgrades, what else should I do? I would like to make it a streetable engine for my 914-6gt replica. Bigger heads... how big? Will the E MFI system work ok? Cheers, Don.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. Last edited by BigD9146gt; 11-09-2006 at 10:49 PM.. |
Try not, Do or Do not
A 73 E has a 70.4 mm crank. That mated to a set of 92mm pistons and cylinders is a 2.8 not a 2.6.
The 908 was an 8 cylinder engine which means the cams had 4 sets of lobes. Plus 908s had twin cams, hard cam to use in a 911. We may have a ID problem here. http://www.earthflix.com/stories/908_3.php ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Max Sluiter
The engine pictured is a type 771. That is a derivative of the grand prix engine which was also used in a couple 904s, the 910,909,and 907. The type 908 engine was like a 911 engine with 2 extra cylinders and a vertical fan. The firing order made alot more vibration until they changed it in the second season with the complicated exhaust for the 180 degree crankshaft.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Thread Tools | |
Rate This Thread | |
