drummer323's Avatar
Question on 3.5 N/A build-up.
Looking at taking the turbo 3.3 case, oil pump, crank and building a larger displacement going n/a. I know in the book it states to use 100mm pistons but can you safely go 102mm? I plan on using all aftermarket studs, perfect bore cylinders, je pistons, carrillo rods, probably s cams unless a better suggestion on cams , its heavy street driven (street raced) twin plug 3.2 heads and pmo carbs, headers with no heat, no smog requirements here. Any advice? Thanks, John.
1977 911 with major upgrades!
Old 02-19-2007, 08:01 PM
Hi:
Make sure you have twin-ignition to run those big-bore motors on pump gas and use the Webcam 120/104 instead of the "S" cams.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-19-2007, 08:55 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Just went 3.3 already thinking 3.5
Just built a 3.3 motor with 100mm bore. Going larger on an older case leaves either very little material left on the case spigots or you end up with a very thin cylinder skirt. I think that Andial did something like this with their 3.7litre engine.
74 911s neverending story. two feet and a jetta for now.
Old 02-19-2007, 09:49 PM
I have made a 102/106.5 3.7 cylinder and have sold quite a few sets through various dealers (it's not in the Pelican catalog since they are custom order - I don't stock them, but just call Pelican and ask for them).
The original andial 3.7's use a 107 case register, our most recent 3.7's use a 106.5 case register, since our alloy is very ductile and strong (I have done thinner cylinders without incident). Knowing our cylinders hold up even with as thin as a 1mm thick skirt, I decided to leave extra material in the case.
What I would not do is run a turbo on the 3.7s since there is no room to flame ring and I would highly suggest twin plugging as a must.
I have done some single plug sets, but the highest compression I have done in that case was 9.3:1.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 02-20-2007, 03:21 AM
user & abuser
i am running a n/a 3.5L using a 3.3L turbo case and oil pump as the base.
100mm mahle P&C's, enlarged 3.2L heads, twin plugged, crank fire ignition, 1 3/4" headers, 46mm webers, carrilo rods, raceware bolts etc, etc....
i am using an S cam, however i would suggust something with a little more top end. The torque is VERY strong from early on, however i would be willing to loose a little to gain some at the top...not that it peaks too soon...but rather i wouldn't mind a surge 5000+.
great engine, allows me to keep up with alot of car that used to be in a different league.
vini vidi vici
Old 02-20-2007, 11:49 AM
drummer323's Avatar
Thanks for all the replies. I've been doing some study of various engine combo's and I like this set up the best. What type of exhaust are you using? Using a G50 or 915 or 930 4spd tranny? I'm considering the 930 short bell-housing tranny and a good clutch package.
Old 02-20-2007, 07:54 PM
user & abuser
i'm using a recently rebuild 915 (5 speed, stock gearing....lots of fun with new power!!). I am using ....someone's stage 3 clutch, with .....i wanna say a powerhaus (2) flywheel.... could be out of left feild there...neither are stock, been a while... anyways, flywheel is light and lets the engine sing to redline, and the clutch grabs hard and never slips...kinda hard to do hill starts....
right now i am running 1 3/4" S.S. B&B's with heater boxes, the long collector version.
they are VERY nice, and are for sale....mostly because in my mid-year these headers don't allow for a proper muffler...not an issue with later cars.
-looking foward to following your build
vini vidi vici
Old 02-20-2007, 09:23 PM
