Cylinder size code question
Is it permissible to mix in a number 3 Size Code cylinder in an engine were all the other cylinders are Size Code 1?
Old 02-26-2007, 07:49 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: Cylinder size code question
As long as the piston matches the cylinder it's OK.
Perfect? no, but you will not notice a performance difference.
It is not advised to run a 1 piston in a 3 cylinder.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-26-2007, 11:47 AM
Thanks Henry. Yes I will be running a size 3 piston in the size 3 cylinder.
Old 02-26-2007, 01:13 PM
