WydRyd's Avatar
Question Turbo 3.6 P&C's in a 964 motor?
Would 100mm turbo P&C's from the 3.6 Turbo 965 or 993TT slip right into a 964 motor, or are the heads different and would require machining to make them fit?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-27-2007, 08:08 AM
beepbeep's Avatar
Certain year of 993TT engines have dished heads where part of piston goes into the head.
But if you only install the pistons and leave the rest as it is (=use 964 heads and cylinders) I believe it will work.
Thank you for your time,
Old 03-01-2007, 03:29 AM
WydRyd's Avatar
Thanks, Goran. Finding 993TT pistons is like finding a pin in a hay stack
Merv
'89 911 Turbo Cab
Old 03-01-2007, 03:44 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Simply machine the tops of the 964 pistons to make the compression you want for your turbo.
We have done it many times with excellent results.
BTW: I think we have 100mm turbo pistons and cylinders for sale.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-05-2007, 07:12 PM
beepbeep's Avatar
No it's not I did it twice. Just check with companies that do big $$ tuning of 993TT's. Chances are they'll have a used set lying around since they swapped them out for JE's or Mahle Motorsports.
But frankly, why don't you just buy a set of JE's? They are less than half price of new set of OEM 993TT's...
Also, when running 993TT pistons in 3.6 with hot cams, you'll probably need to machine valve pockets on pistons somewhat deeper.
Old 03-06-2007, 12:17 AM
Wyd- I have a new set of 993 TT pistons that are for sale-- very convenient to you!
Old 03-08-2007, 11:22 PM
BEFORE 11.4:1 compression
AFTER 8.5:1 compression
Henry Schmidt
Ph: 760-728-3062
Old 03-09-2007, 11:59 AM
Send a message via Yahoo to Lukesportsman
Cool Henry. So Mahle doesn't have hollow domes? How thick are the top of the pistons after machining them? I know some aftermarket, different marque pistons follow the outside shape internally to some degree. Obviously not to closely with the 993's......handy.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 03-10-2007, 04:45 PM
It varies. We put a slight dome on the pistons for more compression and better flame propagation and that leaves the dome at around .300"+.
Cut them flat for 7.5:1 you get around .280".
Henry Schmidt
Ph: 760-728-3062
Old 03-10-2007, 05:54 PM
sprbxr's Avatar
Send a message via Yahoo to sprbxr
Resurrecting this thread from the dead.
Henry
Is the .280" this new thickness of the piston crown?
Any room for increasing valve pocket on the top of the piston?
Justin
Old 09-27-2009, 11:37 AM
Henry
When cut the dome thickness is in excess of .280" . 280" is the number I use for minimum dome thickness for a turbo charged engine.
Henry Schmidt
Ph: 760-728-3062
Old 09-27-2009, 12:55 PM
sprbxr's Avatar
gotcha.
Thanks.
Justin
Old 09-27-2009, 01:23 PM
Resurrecting this thread from the dead too.
Henry, what do you charge to machine 964 pistons down to 8.0:1 C/R?
Also, what do you charge to have the set of 964 cylinders and heads flame ringed?
Old 03-26-2011, 02:50 PM
I may already have a set of pistons to suit your needs sitting on the shelf at a reasonable price. give me a call on Tuesdays.
As for flame rings: ever since we started using Supertec head studs, we find that flame ring heads are unnecessary.
Henry Schmidt
Ph: 760-728-3062
Old 03-26-2011, 06:14 PM
Interesting. At what boost levels though?
Old 03-27-2011, 03:13 PM
A few years back one of our customers made 846 crank hp @ 1.2 bar from his 3.4.
The heads were torqued to 34 lb and upon regular freshen ups showed no sign a head movement or compression release.
Henry Schmidt
Ph: 760-728-3062
Old 03-27-2011, 04:03 PM
That's impressive! My motor is already running ARP fasteners.
The 3.6 question was related to another project I've got in mind
Curious, how much does it typically cost to bore Nikasil jugs from 95mm to 98mm and replate? Is this something you also do?
Old 03-27-2011, 07:53 PM
