Navin Johnson
TimT's Avatar
Cam Timing
Since cam timing is a topic that seems to throw doubts into engine rebuilds..
We recently took a Supercup engine, and twin turboed it
Only 4 cams to time
Initial set up
Fixture and dial indicators in place
Yeap degree wheel
fine adjustments
Cam timing
FYI
'69 911 GT-5
'75 914 GT-3
and others
Old 03-18-2007, 08:23 PM
Navin Johnson
TimT's Avatar
Wonder why that one pic would not post... so here it goes again...
fixture with dial indicators in place
'69 911 GT-5
'75 914 GT-3
and others
Old 03-18-2007, 08:26 PM
Navin Johnson
TimT's Avatar
ok I guess somewhere there is something funky in the filename... so I renamed it
'69 911 GT-5
'75 914 GT-3
and others
Old 03-18-2007, 08:29 PM
Super Moderator
cstreit's Avatar
Nifty tools Tim. You guys make them?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-19-2007, 06:09 AM
Walt Fricke's Avatar
Thanks for a view of how the other 1% lives! That's some engine.
The latest Excellence notes that the 8 cylinder type 771 engine (used in the 907) took the factory 220 hours to assemble.
How long for one of these?
Walt Fricke
Old 03-19-2007, 02:20 PM
304065's Avatar
I read that too, Walt, about the 771. The same paragraph said it took 16 hours to assemble a 906 engine, which is basically a 901. . . then again that's assembly only, not teardown, rework and reassembly.
Back to Tim's topic, what makes this engine's cam timing different than any other four-cam 996 motor? Not to downplay the significance in the slightest, on the contrary, those four-valve water-cooled engines are pretty complicated. Is that Richie in the photo?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-19-2007, 02:29 PM
