vmisquez's Avatar
Rubber trim for engine compartment
Hi All,
I've searched but could not find the part number for the ~3 inch wide trim that attaches to the body and creates seal around the engine compartment when the engine is mounted.
The trim I have in the car now appears to be three piece set and each piece helps build the seal.
Anyone know where I can find a replacement part?
Thanks,
V.
Old 03-20-2007, 02:05 PM
sjf911's Avatar
91150411102-M136
91150411302-M136
I just replaced mine, what a difference.http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911E&section=BDYsl2&page=2&bookmark=13&part_number=911-504-111-02-M136
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-20-2007, 02:12 PM
vmisquez's Avatar
Thanks Steve. I just put a set on order.
Old 03-20-2007, 02:31 PM
KTL KTL is online now
Schleprock
KTL's Avatar
That seal is a bear to install. I highly recommend using silicone spray if you chose not to bend and re-pinch the metal channel that holds the seal in place.
Kevin L
'86 Carrera "Larry"
Old 03-22-2007, 04:39 PM
