Rickw96's Avatar
Question How do you install the RSR seals???
Hello,
I am trying to install the RSR seals on my rocker shafts. I can not get them to stand up to fit in the groove. Am I missing something here??? Is there an easy way to slide them in??? Also, should I put some Dow 111 on the seals?
Rick
Old 03-21-2007, 05:37 PM
Pull them on the shaft and pull them PAST the groove, then sliding the seal back towards the end. As it hits the groove almost all of mine "dropped" in almost totally, a few required me pulling "out" (away from the shat) slightly. The first one took me 10 minutes, the remainder took about 20 seconds each
I don't think I'd use any 111, search for threads, several real experts recommend dry with some oil applied to the oiling hole in the rocker
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 03-21-2007, 06:44 PM
Rickw96's Avatar
rlane,
Thanks so much. I was not pushing them passed the groove. I will check on putting them in dry.
Rick
Old 03-22-2007, 04:20 AM
Did anyone one find a cost effective source for these little overpriced buggers? Almost $5.00 bucks apiece from our host.
Keith Epperly
87 slant nose turbo look carrera cabriolet
Old 03-27-2007, 05:17 AM
Try EBS Racing part #POR040020 $1.50 each
Old 04-08-2007, 11:45 AM
I too installed mine dry and added oil to the rocker openings. I only had slight problem with one rocker arm seal but it went in after careful handling.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-08-2007, 12:05 PM
Senior Member
Superman's Avatar
Absolutely coat them with silicon grease. I did that and they went in fine. No leaks.
Mocha 1978 911SC. "Coco"
Old 04-08-2007, 05:20 PM
Location: Behind the redwood curtain, (humboldt county, way north california)
price update
I ordered 25 of the seals this morning for $2.50 each + 18 shipping
hth,
chris
Old 11-27-2010, 09:10 AM
i installed them gingerly while dripping in oil
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-27-2010, 10:24 AM
KTL KTL is online now
Schleprock
KTL's Avatar
The Dow stuff is not only a lubricant but it helps resist deterioration of o-rings. The stuff is very solvent resistant, so oil doesn't break it down. That being said, you don't want to over-do the use of it. A little bit goes a long way. Big blobs of residual Dow paste are not going to dissolve and could clug up a tiny oil passage, like a camshaft spray bar hole for instance?
Kevin L
'86 Carrera "Larry"
Old 11-30-2010, 03:27 PM
Walt Fricke's Avatar
I don't like lubricants here. The Dow stuff is intended for O ringed joints where the O ring is expected to move a bit back and forth . For instance, the oil return tubes, which move some with thermal changes.
Here you want the ends of the shaft to expand, creating friction against the bore to keep the shaft in place. I don't want any lube there. Maybe that is a baseless fear, since some oil always seems to get out past this metal to metal seal (and past any RSR o rings, too, on my engines) to collect grime. Comes from somewhere anyway.
I worried that these seals would add friction, making the install/remove process more diffucult. Especially if one had to replace a rocker at the track or otherwise with the motor together. However, they seem to go in about as normal.
Which also made me wonder how they were going to do much good. Perhaps expansion of the shaft ends also pinches the ring, forcing it outward? I ought to put hardware in a shaft, measure the gaps, and tighten and remeasure. I may have done this with no measureable change, but am not sure.
Now, if the gap does close some, maybe that creates a role for lubricant - allowing the ring to pinch outward more easily?
Old 11-30-2010, 07:42 PM
EBS_Don's Avatar
I always recommend using a little oil or DC 111 as it's easy to cut the edge of the seal as you push the shaft in. I have seen this happen as the bore edges can be sharp!
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 11-30-2010, 11:12 PM
Those edges of the rocker shaft bore can cut some rubber off the rocker shaft seals when pushing the shafts in. Then the seal won't do it's job as well and may let oil leak by slowly.
I like the idea to take some 1200 grit wet or dry sand paper and using a folded up small piece over the end of your finger - smooth off the sharp edges of the rocker shaft bores just a little bit while the cam tower is off the motor so you can clean it real good afterwards.
If you don't scratch the bores doing that it won't hurt anything and should help the rocker shaft seal slide in there without catching on the previously sharp edge and damaging the rubber seal.
Old 12-01-2010, 05:01 PM
I just put an order in for a set of the seals with EBS. No joke, I received a tracking number from UPS in less than 20 minutes. Unreal turnaround time.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 09-12-2011, 04:30 PM
