mnmasotto's Avatar
Smile Estimate of converting a 3.2 to twin plug ignition.
I am converting my 3.2 to 3.4 or 3.5. I need to figure in the cost of the twin plug ignition system. I think I will go with the 964 distributor setup. Please give rough estimate on cost and a good source for purchase.
Regards, Mark
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 07-20-2007, 10:24 PM
Mark:
We've done a lot of these conversions so perhaps I can help.
Here's what you will need for a Motronic car:
1) 3.6 distributor. (install new belt and vent kit before use)
2) Motronic splitter unit.
3) Extra coil.
4) Plug wire harnesses.
5) Machine heads and lower valve covers, of course.
6) 6 plug wire hold-down clips for the lower plugs.
7) Custom chip for twin-plug operation. (Steve Wong is THE man for those)
If you have the engine apart, I'd suggest that you install the 3.6 crank gear, as well.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-21-2007, 08:40 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Steve,
Could you please elaborate on the above a bit more? What's the rationale in doing this?
Kevin L
'86 Carrera "Larry"
Old 07-26-2007, 04:03 PM
Hi Kevin:
The 3.6 engine distributor crank gear has a slightly different pitch than earlier CW-rotation ones do and this makes for quieter operation as well as extended life.
These are not expensive ($56) and if the case is apart and the 3.6 dual-distributor is to be used, I'd recommend changing that gear to the 3.6 one.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-26-2007, 06:55 PM
abit off center
cgarr's Avatar
I don’t suppose you can just swap dizzy gears?
______________________
Craig
G2Performance
Old 07-27-2007, 05:23 AM
You can certainly do that if you have the correct one at hand. Porsche doesn't sell them,.......
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-27-2007, 09:03 AM
mnmasotto's Avatar
How much money?
Can anyone give me a rough dollar estimate? Please!
2007 997 GT3 - SOLD
Old 07-27-2007, 10:14 PM
Hi Mark:
Call me sometime during business hours; I don't post any prices here,..
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-28-2007, 12:11 AM
