I am converting my 3.2 to 3.4 or 3.5. I need to figure in the cost of the twin plug ignition system. I think I will go with the 964 distributor setup. Please give rough estimate on cost and a good source for purchase.
Regards, Mark
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD |
Mark:
We've done a lot of these conversions so perhaps I can help. ![]() Here's what you will need for a Motronic car: 1) 3.6 distributor. (install new belt and vent kit before use) 2) Motronic splitter unit. 3) Extra coil. 4) Plug wire harnesses. 5) Machine heads and lower valve covers, of course. 6) 6 plug wire hold-down clips for the lower plugs. 7) Custom chip for twin-plug operation. (Steve Wong is THE man for those) If you have the engine apart, I'd suggest that you install the 3.6 crank gear, as well.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Schleprock
Steve, Could you please elaborate on the above a bit more? What's the rationale in doing this?
Kevin L '86 Carrera "Larry" |
Hi Kevin:
The 3.6 engine distributor crank gear has a slightly different pitch than earlier CW-rotation ones do and this makes for quieter operation as well as extended life. These are not expensive ($56) and if the case is apart and the 3.6 dual-distributor is to be used, I'd recommend changing that gear to the 3.6 one.
abit off center
I don’t suppose you can just swap dizzy gears?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
You can certainly do that if you have the correct one at hand. Porsche doesn't sell them,.......
How much money?
Can anyone give me a rough dollar estimate? Please!
Hi Mark:
Call me sometime during business hours; I don't post any prices here,..
