Mad Aussie Porsche nut
Anyone used Weltmeister Hydra-stops.
I have seen these advertised - has anyone used them - what do they actually do ?
They are simple spacers that clamp onto the tensioner shaft and act as a mechanical stop to prevent total tensioner collapse if a tensioner fails.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Super Moderator
Plenty in use and they do work. Pelican carries them.
abit off center
Is there anyway to tell when they work? Could you have a failed tensioner and never know it? I did the internal mod to mine
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
cgarr,
Whats the internal mod you did ? |
abit off center
They worked for me.
Back before they invented the tensioner upgrade I used them and they saved my engine on a 77 930. When the tensioner failed you could hear a noticable chain noise, however the hydra stops prevented total collapse of the tensioner. Really cheap insurance if running the original tensioners.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
I made and installed the "internal" type also. I call them "Jerry Woods slugs". Turns out there is a bushing at Orchard Supply I think it is a 5/8" bushing made from brass. The OD of these fits perfect in the ID of the tensioner. Cut off a piece and sand down. I went with about a 1.5mm clearance. So far so good.
Great info guy's. Thanks for the help
