GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Quick Reference - Best Sealants
Im tearing apart my 2.4 to get rid of Oil Leaks.. I have waynes book and want to know based on Users Use whats the BEST "Sealants" to use on these Areas:
Between Engine Case and Cylinders
Between Cylinders and Heads
Between Heads and Cam Tower
RSR Seals on Rocker Shafts. Anything else added to the rocker shafts on install?
Crank Pulley Seal?
- or any type of similar seal
On All Paper Gaskets ? ie Cam Covers, Valve Covers,
or anything else I've missed
THANKS..
Old 09-09-2007, 08:31 PM
304065's Avatar
The Complete Engine Sealant Thread...
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-10-2007, 06:47 AM
GotaT's Avatar
Perfect!!! Thanks!
Old 09-10-2007, 09:01 AM
I like the performance of Dow 730 on the pulley seal. I don't like the price ~$90.00 tube.
Mark
1987 Carrera
2018 GMC Sierra Denali 2500 Duramax
2012 Harley Davidson FLHX Street Glide
Old 09-10-2007, 06:48 PM
GotaT's Avatar
Ok.. The only thing that I did not notice was
Cylinder to Heads.. Whats recommended
Curil T .. as used on cylinder to case
Also,
Some Recommend Three Bond 1104/1194 and others Permatex Anaerobic Sealant for Cam Towers to Heads.
Are they essentially equivalent?
Old 09-10-2007, 06:52 PM
Hi Mitch,
For my 3.2 rebuild, cylinder to heads = nothing. For the cam towers to heads I used Loctite 574. Just make sure everything is sterile clean!
Mark
1987 Carrera
Old 09-11-2007, 03:25 AM
GotaT's Avatar
Boxer.. you say Nothing b/n the Cylinder to Heads..
I am getting some oil leakage bn these on 2 of the cylinders.. What Should I do?
Old 09-11-2007, 08:09 AM
http://www.aircooledtechnology.com/store/home.php?cat=311
A good reference for which products can be used where by product.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 09-11-2007, 11:07 AM
GotaT's Avatar
I am seeing a little oil leak between the Cylinders and Jugs on, I think, 2 of the cylinders. I'll try to get a pic later. Anyone experience this.. whats the fix? any type of sealant?
Old 09-12-2007, 10:35 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Case sealing suggestions :
Outer case halves perimeter : Threebond 1104
Bearing web surfaces: Loctite 574
#8 Bearing O-Ring: Threebond 1211
Case Thru Bolts: Dow Corning 111 on Green Viton O-Rings
Flywheel Seal: dry
Front pulley Seal: dry
Intermediate Shaft Cover to Case: o-ring Dow111 , gasket style 574
Oil Breather Cover to Case: Loctite 574
Cylinders to Case: Curil T
Cam Towers to Cylinder Heads: Threebond 1104
Cam Chain Housings to Case gaskets : Loctite 574
Cam Chain Housings to Cam Towers gasket: Loctite 574
Cam Chain Housing Cover to Cam Chain Housing Gasket : Loctite574
Gaskets: Thin coat of Loctite 574
No sealant is used on pulley or flywheel seals and no sealant is used between the cylinders and heads.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-12-2007, 03:34 PM
GotaT's Avatar
Thanks.. What would cause a little "blow by" between the Cylinders and Heads? ?
Old 09-13-2007, 06:34 AM
The leaking that occurs between the cylinder and heads on 911 engines is not blow by.
The leaking is actually leaking oil caused by the fact that the horizontally opposed cylinders allow oil to rest in the cylinders.
As the engine heats the heads seal from the expansion of the components. When hot the heads seal almost perfectly.
As the engine cools the cylinders cool from top to bottom because of the proximity of the exhaust.
Because of this uneven cooling the cylinder to head seal become compromised and the oil resting in the cylinders seeps out.
This was the reason for installing the ever troubling Delivar studs. This uneven cooling is also the reasoning behind the silly no fin turbo cylinder of the late 70s and early 80s.
On the early 964 engines this phenomenon was intensified because of the wider stud spacing and weak head design of those engines.
The only cure for this phenomenon is top quality parts (new cylinders, quality head studs and gaskets when offered) and proper assembly techniques.
Henry Schmidt
Ph: 760-728-3062
Old 09-13-2007, 06:56 AM
dweymer's Avatar
What about the on-engine oil cooler seals? lightly oiled I assume?
Donnie
Currently Porsche-less.....
Old 09-17-2007, 10:42 PM
Dry, no sealant or lubricant is necessary on these seals.
Henry Schmidt
Ph: 760-728-3062
Old 09-18-2007, 05:59 AM
dweymer's Avatar
thx
Donnie
Old 09-18-2007, 07:36 AM
Tags
case sealants
