gigem75's Avatar
my rebuild
first photos.....
Old 09-19-2007, 08:30 AM
efhughes3's Avatar
That's it??!!??
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-19-2007, 01:17 PM
gigem75's Avatar
first but not last
Old 09-19-2007, 06:00 PM
GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Looks Great.... you painted them and media blasted the cam housing ? Mine look very similar!
Keep itup!
Old 09-19-2007, 06:14 PM
gigem75's Avatar
I stop at the shop and blast a couple of parts each day, one step at a time....
the paint is International Harvester Red preimum farm implement paint. it is supposed to stand up to head, grease, oil, wear, and just about anything else one could throw at it. at 7 bucks a can from Tractor Supply it ought to!
After blasting the covers, I put them in the dishwasher and the surface came out a lot smoother than it was before. Much better finish than just painting after blasting.
Old 09-20-2007, 06:30 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
You should get the correct length M8 studs for the two that are excessively long on the intake side. Looks good though
Scott Kinder
kindersport @ gmail.com
Old 09-20-2007, 01:42 PM
gigem75's Avatar
You WIN!!!!! I was wondering how long it would take for that to get noticed and I will!
Old 09-20-2007, 01:57 PM
Jeff Alton's Avatar
You cetainly have some photo skills! what camera are you using?
Give us the details on the build........
Cheers
www.turn3autosport.com
Old 09-20-2007, 04:40 PM
gigem75's Avatar
The camera is just a Nikon D2X, light box above, gel on the back light, nothing special.
I recently acquired a 70 911T.
I had just replaced both rear wheel bearings and it was so smooth, but only got about a hundred miles down the road before the rocker shaft fell out.
It has 125k, was driving to Corpus for an Ag reunion when a rocker shaft slipped out and I lost a valve with the consequent oil deluge. The motor had the usual oil leaks so I figured it was time. I've been air honeing all the parts that will get paint. New aluminum jugs with new pistons and rings, valve touch up, new bearings of course, oil pump is good, it has the tensioner upgrade but I'm getting the collars to prevent tensioner piston from failing, new chains, new upgraded oil pressure relief pistons and springs, oil passage restrictor upgrade in head. Micropolishing the crank, glass beaded the rods. No major performance mods, just trying to put it back with good parts and procedures. The car was originally blue but has been done in black everywhere. The doors have some serious rust at the bottom, other than that it's solid everywhere else. Just a damn fun car to drive, almost as much fun as the Alfas I had in the past, well maybe a little more fun
Old 09-20-2007, 07:38 PM
Jeff Alton's Avatar
Alfa's are fun
Sounds like a good project, you are in good hands on this board.
Cheers
Old 09-20-2007, 07:43 PM
You say the oil pump is good and you are using upgraded pressure relief valves and springs. These statements don't go together. You need a later oil pump with case bypass mod or you need to keep the old pressure relief valve and spring. I don't think you can put collars on the hydraulic tensioners.
-Andy
Old 09-20-2007, 09:20 PM
gigem75's Avatar
Humm, John at Pelican led me through what I needed. The pressure relief upgrade is a piston without the holes in the side. We discussed my oil pump and he recommended the new oil pressure relief solution.
We also talked about the tensioner upgrade and he recommended the collars for those tensioners. He said he had them on his engine.
If this information is not correct I want to find out now and not later.
Old 09-21-2007, 07:23 AM
My information on the pressure relief valves cames from Bruce Anderson's 911 performance handbook. He says if you mix the pressure relief valves with the wrong case bypass you will introduce oil pressure problems. The relief valve with the holes is for the old pump with the bypass that goes into the bottom of the case (standard on pre75 911 cases). The new bypass is for engines with the updated pump and bypass that goes to the input galley of the oil pump(standard on post 75 911 cases).
I haven't seen a collar for the hydraulic tensioners but maybe that is something new that I don't know about. If they fit then probably not a problem using them.
I don't know who John is but maybe he can explain to you about the 2 types of oil pumps and what the bypass mod is. If he knows all about that then maybe he is right about the pressure relief valve upgrade working ok with your pump.
-Andy
Old 09-21-2007, 08:10 PM
gigem75's Avatar
I certainly appreciate the info. Knowledge is power and I'll double check with him. Got to give them a call Monday anyway, got my parts today but no book. Still need to order a couple of exhaust studs and rocker cover studs and a couple of other things. I'm still cleaning and preping so there is no great rush.
Old 09-22-2007, 05:21 PM
gigem75's Avatar
Upon close examination of the oil pump I noticed the pick up tube seemed to be loose. I gave it a gentle tug and it came out of the housing. It appeared to be jb or devconed as the only means of attachment. Is this right? Should I re-glue it back in. If that is the way it's done I wish I would never had found out because having my rebuild depend on how well something is glued in to something else is rather disconcerting to say the least.
Old 09-26-2007, 11:26 AM
abit off center
cgarr's Avatar
Hey, I have that same table saw/workbench
______________________
Craig
G2Performance
Old 09-26-2007, 12:10 PM
gigem75's Avatar
far out!
Old 09-26-2007, 12:55 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Talking
Originally Posted by gigem75 View Post
The camera is just a Nikon D2X, light box above, gel on the back light, nothing special...
Nothing special, hahahahahahahaha
Keep those great photos coming!!
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 09-27-2007, 09:50 AM
gigem75's Avatar
a kodak moment
Old 10-02-2007, 05:51 PM
robmog's Avatar
great pictures, but...
where's your engine stand?
how did you assemble and torque the case halves?
or is this trick photography and photoshop?
keep up the good work,
bob
Old 10-02-2007, 07:15 PM
