adelis's Avatar
What do I do with my Alusils?
I have a set of Alusil cylinders and Mahle pistons with 76k from an '87 3.2. No damage that I can see, but I have not measured them and there are no rings on the pistons currently. They were replaced by a set of 3.4 P&Cs from Supertec. So what do I do with the Alusils? Do they have any value at all? I am headed to the dump tomorrow and I don't mind taking them with me if that's what it comes to. Thanks.
--Angelo Delis--
1987 Carrera Coupe GP White
2006 Tundra
2003 Audi A6 Quattro 2.7T
2000 Audi TT 1.8T
Old 02-03-2008, 08:24 AM
There are some people who would re-ring them and use them if the ring lands are ok. You could put the used parts list. If the ring lands are in spec they could be worth a couple hundred dollars. If the lands are out of spec then they are basically worthless.
-Andy
Old 02-03-2008, 08:49 PM
adelis's Avatar
-Andy
Thanks for the response. I will give that a try.
--Angelo Delis--
2006 Tundra
2000 Audi TT 1.8T
Old 02-04-2008, 04:45 AM
Your 3.2 Alusil cylinders can be bored and replated. I've sold several sets of 3.2 Alusils on the board.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 02-07-2008, 08:42 AM
dtw dtw is offline
GAFB
EBS buys Alusil cylinders.
Several BMWs
Old 02-07-2008, 09:12 AM
easure them and if they are within spec thay can be reused. You may need to ship them to a machine shop that specifically cleans and has the specific tools to hone the alusils.
Old 02-07-2008, 11:04 PM
Jeff Alton's Avatar
They certainly have a core value to folks who bore them to 98mm. Call EBS and see, but I guessing in exess of 400.00.... Same is not true for 95mm SC cylinders.
I have re ringed a couple of sets of alusil with success, as have others, but I still feel it is a crap shoot.
Cheers
www.turn3autosport.com
Old 02-07-2008, 11:17 PM
adelis's Avatar
Thanks for all the replies. I don't want to reuse them, I want them to go away! A deal is in the works.
--Angelo Delis--
2006 Tundra
2000 Audi TT 1.8T
Old 02-07-2008, 11:46 PM
