The oil leak from the cooler is probably off the thermostat seal, I have had a rash of thermostat oil seal not working so I ve gone to sealing above the O ring with sealant.
Bruce |
![]() ![]() Had a chip repaired today..it's not perfect but pretty servicable. And there was no charge again. I do love small towns. Thanks for the suggestions. I checked the distributor for play and it felt good. The only time I get a stumble is when my foot is just touching the peddle. Mayne my fat foot is just bouncing on the peddle. I will check the thermostat for leaks (thats easier than the cooler or the nuts behind the cooler). What kind of sealer are you using on the o-ring? ![]() vitals still look good. I am getting a little oil spray out of the exhaust when i rev the engine. I have 320 miles on her so far. |
Straight shooter
The internals of the distributor are likely to be where an issue would lie. You may also have a plug with a gap that is off and causing a slight miss at low loads... or a fuel injector that is lazy. Could be a number or combination of things.
Oil out the exhaust is interesting. For fear of sounding like Captain Obvious you will want to watch the oil level and consumption closely. New rings will take a bit to seat fully... my previous life in VW engines was seating rings with cheap oil and varied operating conditions including wide open throttle, high rpm with full vacuum breaking while only at full temperature. Avoid prolonged constant rpm and seek hills where you can vary the load including vacuum conditions during deceleration. Don't pussy foot it or the rings won't seat or wear in properly.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Video from yesterday
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
I checked my battery today and it has 12.2 v cold and 12.3 v after a 45 min spirited drive. This is a 6 or 7 year old battery.
Do youthink this could be the issue I am having with the stumbling? My leaks are coming from triangle of doom (better than a leaking case or oil cooler), I will get my fat head back there soon. Merry Christmas & thanks for all the help.
Straight shooter
That's a normal voltage for car off, battery resting.
-Andrew
Thanks Andrew.
Check the fuel pressure. Do you have an adjustable fuel regulator.
I drove the car this am and it ran like crap, bucking and sputtering. It will idle fine and runs fine at wot, but cruisingabout 3000rpms it has issues. I drove 30 minutes and thought it was going to leave me on the side of the road. I stopped to take take my son into school and came back out and it ran like a top when I started it up.
Why is the probllem coming and going? It seems to go away when I restart the car after it is warm. I was able to repeat the symptoms and the cure again tonight. Thanks for all the help.
Straight shooter
-Andrew
The Motronic has both an idle switch and a WOT switch which I assume changes fueling and timing. It sounds like you are running lean in between which may mean a vacuum leak or problem with your AFM or related component.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
I was able to drive some more today. I have 550 mile on her so far and am going to change the oil and adjust the valves and try to find the leak.
The studdering is still there but only starts after I have reved the engine over 3k rpms. I removed the distributor cap and can see evidence of the rotor hitting the cap and making a groove in it. What are the best options on the distibutor? I am still trying to figure out what is happening with the studdering. I am glad I used the ARP rod bolts, bounced it off 7k rpms this afternoon. The engine is still running fine but I am wondering how high this thing will turn, the engine was still pulling hard at 7k.
What a good job following your build/install
Peppy -
I was able to look at your thread from the beginning to the last post. I really appreciate the pictures, and I love the way you took the time to post pictures nearly at every turn. Your car looks very similar to my fathers: almost identical in appearance. Except Dad's was repainted dark blue with the basic beautiful tu-tone wheels... Almost scary! Your thread really has me excited to get Dad's car back on the road. Nice work on the build, and thank you for all of the pictures and comments in the thread.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. Last edited by Robey5; 01-06-2013 at 05:02 PM.. |
known 3.2 fix its........
rod bolts valve guides valves springs crap fuel line change to aircraft fuel line updatum clutchem updatum G-50 since yers is a 88 may already have parts from p.o. 8th journal seal theres a few for starters. the only cheap in the equation is yer labor. ![]() .................................................. .................................................. ... 2013 MERCEDES BENZ SL-CLASS |
600m mile oil change and valve adjustment
I got the oil changed and the valves adjusted yesterday. Glad to report that all rockers where still in place and I think I found my oil leak and vacuum leaks.
![]() ![]() Looks like anti-seize when I wipe it off. ![]() Oil leak was the breather hose. I was too cheap to replace it. The hose was cracked and brittle, I put a band-aid on it and tightened the clamp a bit more. ![]() Suspected vacuum leaks. The one above the oil filter was not really connected, I pushed it on better and while driving the car around to get the oil warm the missing was not present. I hope that was the fix. ![]() ![]() ![]() Not a great picture, but you can see where the rotor is hitting the cap. I have a new cap and rotor I will install when I change the plugs.
Straight shooter
Situation normal. Looks like you're doing just fine.
I changed the plugs yesterday, I think they look ok. My fix on the breather hose didn't stay (with that hose off the engine cuts off under load, it would idle but I couldn't drive it.
I cut the end off the hose and was able to clamp it down and it is running fine now. Maybe I should go ahead and replace that hose. ![]() I think I need to check the fan on the oil cooler, I have never heard it run. ![]()
spark plug looks a bit lean...I would always stay on the rich side if i were you...especially w/ air cooled engines...= 12-13.5 afr...depends on if a carb or f/i set up engine...
I live for 911 tweaks... |
hmm - the black base and non-grey tip tells me its not lean at all. At the gap it appears to be slightly black, should be grey ...
Mike 97 993TT Arena Red - "Scarlett" |
![]() ![]() A few more plug pictures.
