http://forums.pelicanparts.com/uploa...1350082942.jpg
I.got the hoses figured out and the engine is back in thr car. r. |
http://forums.pelicanparts.com/uploa...1350141257.jpg
Old gas stinks. http://forums.pelicanparts.com/uploa...1350141279.jpg http://forums.pelicanparts.com/uploa...1350141291.jpg The engine and transmission balance pretty well right here. I got this from 87 Carrera engine drop http://forums.pelicanparts.com/uploa...1350141318.jpg It's in...now plug everything in. http://forums.pelicanparts.com/uploa...1350141330.jpg http://forums.pelicanparts.com/uploa...1350141337.jpg |
Woah... nice progress. Looks like you're about ready for the moment of truth.
Ok now I have issues...tried to start it today.
1. Fan is rubbing in housing 2. Fuel is leaking from engine hose (I don't know where yet) 3. Engine will not turn over by the fan pulley 4. The fuse I pulled for the fuel pump evidently is the wrong one. 5. Starter is not spinning. |
1. You had 3 nuts to tighten the fan into the housing, possibly not equally tight.
2/ Fuel leaking is standard problem on the Carrera. I ll take a picture later and include all the possible leaks. 3 You might be filled with gas in a cylinder, pull the plugs and see if it turns then. 4 You shouldnt hear the fuel pump running when youre starting the engine. The relay under the seat controls the fuel pump circuit. 5/ A lot of the Carrera starters have 2 attachment points possible with the 5mm screw, try the second further out point. I ll get a couple pictures separately for you. Bruce |
Thanks Bruce, the fan was fine until I put the belt on. The fuel leak is on the passenger side on the back of the engine.
I am thinking the fuse I pulled has something to do with the starter not spinning. |
this is the fuel line from the filter (long hose, no attachment yet) to the rear connectors each side of the fan to fuel rails.
The long hose to the trar of the picture crosses left to right to the vacuum pods. The small loop off the vacuum pod hose is a leak possible too. Starter end of the bendex you can see both small screw hole for the yellow wire..only one works. Bruce http://forums.pelicanparts.com/uploa...1350340003.jpg http://forums.pelicanparts.com/uploa...1350340020.jpg http://forums.pelicanparts.com/uploa...1350340038.jpg |
Back of the engine where the fan is or where we cannot see forward?
Bruce |
Where we can't see forward. I could hear it dripping.
That would be the forward hose between the pods. the picture is the right forward connector. Remove the aircleaner box and this is visible.
Bruce http://forums.pelicanparts.com/uploa...1350343755.jpg http://forums.pelicanparts.com/uploa...1350343777.jpg |
That's what I was thinking Bruce.
Is the power for the starter on the engine wiring harness or is there another wire under the car for power? These are the only wires I connected to the starter. http://forums.pelicanparts.com/uploa...1350344062.jpg |
There should be 2 wires on the heavy connector on the starter. One red from the alternator and one black coming along the transmission or the right stuck up behhind a brake line or shock or hot air tube. Thats the power from the battery.
Bruce |
Damn glad I didn't burn it to the ground, I did not connect the power to the starter and had a fuel leak almost on top of it.
Do I need to remove the DME relay to prime the oil pump? |
I did disconnect the battery before I left today.
You shouldnt need to prime the fuel pump but yes if you do, run a jumper from the battery to the fuel pump fuse, that will make the pump run and charge the system. If you have a leak the work is fruitless.
Bruce |
To do the oil system, yes pull the relay and no plugs in and turn it for enough to see the pressure on the guage fluctuate. Then you know you have oil to the cams and through the whole system.
Bruce |
Thanks again Bruce, I will try again Friday.
Bruce, it was exactly as you said.
Both ends of the fuel line where leaking at the regulators and the u shaped line was also leaking. The fan was exactly what you said. I did not have the alternator seated in the housing. I pulled the plugs and turned the engine with the fan. I will turn it over with the starter tomorrow and build oil pressure. If all goes well I will start it tomorrow. Thanks for all the help. |
I thought chips where plug and play I am having to solder mine in.
OK, I screwed that up too. |
Remember if it doesnt start and everything seems to be in place, the flywheel sensors are the same but do 2 different things. If they wernt marked, change them and once you get started, put some fingernail polish on one set so there is no mistake next time.
Bruce |
Ok, I have mailed the computer and chip to Russell Berry for him to fix.
I hope to have this thing going soon. |
That's my first anxiety point - avoiding damage to the engine with the floor jack, or performing a "drop" off the jack! I've read all the "drop" threads, but I like your minimalist approach. Best of luck and great work, looking forward to reading about a successful launch! GK |
GK I got the idea for the rags from here 87 Carrera engine drop (23 of 36)
Syncroid did the pictures and the engine balanced a lot better than with the contraption I made. The engine and transmission is pretty stable on the jack. Also the power unit is about 3 inches lower. |
Peppy, Anxiously awaiting the next installment of your saga...what's going on, man?
I too will be performing a rebuild soon and will use your thread as a reference. I also have a friend that has successfully completed several rebuilds, no Porsche rebuilds, but he has all the tools (gauges, lifts, engine stand, etc.). Looking forward to you making an announcement that your machine has roared to life! |
I hope to turn the engine over to build oil pressure tomorrow. |
I turned the key and she spun over with ease. The oil light went out in just a few seconds, no oil leaks yet.
Now to get that computer back in, the suspense is killing me. |
Well done Peppy...can't wait to see the post that you've got it started!
Will you be posting a summary of the build with a rundown of costs? Great Post |
Come on, Peppy...what gives?!
Still no computer, it should be here first of the week.
Great read .. Thanks for posting and good luck with the last steps!
All clean and still waiting.
http://forums.pelicanparts.com/uploa...1353254494.jpg http://forums.pelicanparts.com/uploa...1353254512.jpg My son has never gone for a ride in the Porsche. http://forums.pelicanparts.com/uploa...1353254525.jpg |
Peppy,
He looks like a great son and future Porsche driver, just dont scare him too much on the first launch ! Vr, |
What's doing??????? Peppy, where you been bro?
Still waiting patiently for the computer to return.
Computer...
Still working on it, will get it done this week if I don't hit any further snags. So far I've used parts from 3 other computers, it's coming together. Thanks for sending me the link to the thread!
Regards, Russell |
Christmas is coming... would be a good time for a startup.
-Andrew |
Start up has happened.:D I have video but, am having issues getting it off my phone.
http://forums.pelicanparts.com/uploa...1355334289.jpg http://forums.pelicanparts.com/uploa...1355334304.jpg Case plug. http://forums.pelicanparts.com/uploa...1355334308.jpg Tank plug http://forums.pelicanparts.com/uploa...1355334327.jpg Will the idle come down on its own when the engine breaks in, or will I need to adjust it? http://forums.pelicanparts.com/uploa...1355334333.jpg |
Still no luck with the video, but I have more pictures.
all dry so far http://forums.pelicanparts.com/uploa...1355351301.jpg http://forums.pelicanparts.com/uploa...1355351311.jpg |
| All times are GMT -8. The time now is 08:06 PM. |
