-   -   The Begining (http://forums.pelicanparts.com/911-engine-rebuilding-forum/397314-begining.html)
peppy 08-24-2012 01:59 PM
Originally Posted by KTL (Post 6932954)
As long as they're the right size for the shank of the bolt, copper is fine. Just need something relatively soft to crush and seal the oil from weeping out.
Thanks Kevin, that's what I wanted to hear.
peppy 08-26-2012 07:56 AM
http://forums.pelicanparts.com/uploa...1345992964.jpg
http://forums.pelicanparts.com/uploa...1345992980.jpg
Now to figure out how to time the cams.:D
Flat6pac 08-26-2012 10:25 AM
Get your chain boxes on and measure your depth. After you get your depth set, assemble everything, rails, tensioners, idlers
Back the flywheel so Z1 is at 10 oclock, now you can turn both the cams to have the keyway up. Bring Z1 back to center case. Pin both cams, keyway up.
Z block #1 intake..have you set your rockers?
Bruce
peppy 08-26-2012 10:51 AM
Bruce, by set your rockers do you mean the lash? If so than no, I just installed them.
How much would the depth change? I am reusing all the original parts.
Flat6pac 08-26-2012 12:17 PM
The depth wont necessarly change but I like to know the math is right.
Adjusting the rockers, just do the intake on 1 and 4 befory you put the dial guage on.
Bruce
peppy 08-26-2012 12:24 PM
Thanks, Bruce.
peppy 08-27-2012 03:01 PM
Glad I measured...evidently 5 years ago when I bagged and labeled everything I did not know the left from right side of the engine.
peppy 08-27-2012 04:10 PM
http://forums.pelicanparts.com/uploa...1346108905.jpg
The left side is hard to measure accurately...my straight edge is too wide for my calipers.
peppy 08-30-2012 08:36 AM
Ok, I got everything measured and within spec.
I found it was easier to convert to mm and do the math than using the specs in inches. I think it was the rounding with the calculator that was screwing me up.
peppy 09-02-2012 06:36 PM
Ok, another question. When you preload a dial gauge do I use the red numbers when it is turning backwards?
Flat6pac 09-02-2012 07:46 PM
With a preload, youre numbers will be going toward 0. So if you preload 5mm and you set the cams at 1.25 you will have 3.75 preload left. You just need enough preload of the guage so you dont run out of measurment.
Easiest thing to do is set the Z bar, load the dialguage and lock it in somewhere in the middle of the travel. Set the outer dial to zero on the point. 1.25 is a full sweep of the pointer, plus
1/4 sweep.
My rule of thumb is, each peg adjustment is approximately .15mm on the dial. Sweep past the 1.25, pull the pin and reset it about 1.40. Take back tension on the chain and you should settle in about 1.25.
You really have to play with it until you get the numbers in.
Bruce
peppy 09-03-2012 04:17 AM
Thanks again Bruce.
peppy 09-03-2012 08:29 AM
http://forums.pelicanparts.com/uploa...1346686045.jpg
Here is a picture of 1.26 mm overlap with 10mm preload.
Flat6pac 09-03-2012 10:11 AM
Be sure you load the back pressure on your chain. The other side is way more fun getting a match.
Bruce
peppy 09-03-2012 01:29 PM
Thanks for all the help. A few pics of the timing of the cams again. I also got the tensioners and the distributor installed.
http://forums.pelicanparts.com/uploa...1346703746.jpg
http://forums.pelicanparts.com/uploa...1346703769.jpg
http://forums.pelicanparts.com/uploa...1346703851.jpg
http://forums.pelicanparts.com/uploa...1346703865.jpg
http://forums.pelicanparts.com/uploa...1346703880.jpg
Flat6pac 09-03-2012 03:43 PM
Its all over but the shouting....
Bruce
peppy 09-15-2012 07:38 AM
long block done
http://forums.pelicanparts.com/uploa...1347719749.jpg
headers installed
http://forums.pelicanparts.com/uploa...1347719750.jpg
http://forums.pelicanparts.com/uploa...1347719753.jpg
http://forums.pelicanparts.com/uploa...1347719865.jpg
peppy 09-21-2012 01:36 PM
Sent the injectors to witchhunter to clean them up and ordered a rebuild alternator locally.
I was trial fitting the exhaust today and found rat poison pellets in my muffler. I spent a couple of hours flushing it out.
Lapkritis 09-21-2012 02:53 PM
Dedication. Nice work - looking forward to the start-up.
peppy 09-22-2012 05:29 PM
http://forums.pelicanparts.com/uploa...1348360150.jpg
Gettinng closer
