-   -   The Begining (http://forums.pelicanparts.com/911-engine-rebuilding-forum/397314-begining.html)
peppy 10-12-2012 04:08 PM
http://forums.pelicanparts.com/uploa...1350082942.jpg
I.got the hoses figured out and the engine is back in thr car.
r.
peppy 10-13-2012 08:19 AM
http://forums.pelicanparts.com/uploa...1350141257.jpg
Old gas stinks.
http://forums.pelicanparts.com/uploa...1350141279.jpg
http://forums.pelicanparts.com/uploa...1350141291.jpg
The engine and transmission balance pretty well right here. I got this from 87 Carrera engine drop
http://forums.pelicanparts.com/uploa...1350141318.jpg
It's in...now plug everything in.
http://forums.pelicanparts.com/uploa...1350141330.jpg
http://forums.pelicanparts.com/uploa...1350141337.jpg
Lapkritis 10-14-2012 03:42 PM
Woah... nice progress. Looks like you're about ready for the moment of truth.
peppy 10-15-2012 01:21 PM
Ok now I have issues...tried to start it today.
1. Fan is rubbing in housing
2. Fuel is leaking from engine hose (I don't know where yet)
3. Engine will not turn over by the fan pulley
4. The fuse I pulled for the fuel pump evidently is the wrong one.
5. Starter is not spinning.
Flat6pac 10-15-2012 02:46 PM
1. You had 3 nuts to tighten the fan into the housing, possibly not equally tight.
2/ Fuel leaking is standard problem on the Carrera. I ll take a picture later and include all the possible leaks.
3 You might be filled with gas in a cylinder, pull the plugs and see if it turns then.
4 You shouldnt hear the fuel pump running when youre starting the engine. The relay under the seat controls the fuel pump circuit.
5/ A lot of the Carrera starters have 2 attachment points possible with the 5mm screw, try the second further out point.
I ll get a couple pictures separately for you.
Bruce
peppy 10-15-2012 03:24 PM
Thanks Bruce, the fan was fine until I put the belt on. The fuel leak is on the passenger side on the back of the engine.
I am thinking the fuse I pulled has something to do with the starter not spinning.
Flat6pac 10-15-2012 03:27 PM
this is the fuel line from the filter (long hose, no attachment yet) to the rear connectors each side of the fan to fuel rails.
The long hose to the trar of the picture crosses left to right to the vacuum pods.
The small loop off the vacuum pod hose is a leak possible too.
Starter end of the bendex you can see both small screw hole for the yellow wire..only one works.
Bruce
http://forums.pelicanparts.com/uploa...1350340003.jpg
http://forums.pelicanparts.com/uploa...1350340020.jpg
http://forums.pelicanparts.com/uploa...1350340038.jpg
Flat6pac 10-15-2012 03:30 PM
Back of the engine where the fan is or where we cannot see forward?
Bruce
peppy 10-15-2012 03:50 PM
Where we can't see forward. I could hear it dripping.
Flat6pac 10-15-2012 04:29 PM
That would be the forward hose between the pods. the picture is the right forward connector. Remove the aircleaner box and this is visible.
Bruce
http://forums.pelicanparts.com/uploa...1350343755.jpg
http://forums.pelicanparts.com/uploa...1350343777.jpg
peppy 10-15-2012 04:35 PM
That's what I was thinking Bruce.
Is the power for the starter on the engine wiring harness or is there another wire under the car for power?
These are the only wires I connected to the starter.
http://forums.pelicanparts.com/uploa...1350344062.jpg
Flat6pac 10-15-2012 04:50 PM
There should be 2 wires on the heavy connector on the starter. One red from the alternator and one black coming along the transmission or the right stuck up behhind a brake line or shock or hot air tube. Thats the power from the battery.
Bruce
peppy 10-15-2012 04:53 PM
Damn glad I didn't burn it to the ground, I did not connect the power to the starter and had a fuel leak almost on top of it.
Do I need to remove the DME relay to prime the oil pump?
peppy 10-15-2012 04:56 PM
I did disconnect the battery before I left today.
Flat6pac 10-15-2012 05:08 PM
You shouldnt need to prime the fuel pump but yes if you do, run a jumper from the battery to the fuel pump fuse, that will make the pump run and charge the system. If you have a leak the work is fruitless.
Bruce
Flat6pac 10-15-2012 05:11 PM
To do the oil system, yes pull the relay and no plugs in and turn it for enough to see the pressure on the guage fluctuate. Then you know you have oil to the cams and through the whole system.
Bruce
peppy 10-15-2012 05:19 PM
Thanks again Bruce, I will try again Friday.
peppy 10-19-2012 02:15 PM
Bruce, it was exactly as you said.
Both ends of the fuel line where leaking at the regulators and the u shaped line was also leaking.
The fan was exactly what you said. I did not have the alternator seated in the housing.
I pulled the plugs and turned the engine with the fan. I will turn it over with the starter tomorrow and build oil pressure.
If all goes well I will start it tomorrow.
Thanks for all the help.
peppy 10-19-2012 03:10 PM
I thought chips where plug and play I am having to solder mine in.
OK, I screwed that up too.
Flat6pac 10-20-2012 03:53 AM
Remember if it doesnt start and everything seems to be in place, the flywheel sensors are the same but do 2 different things. If they wernt marked, change them and once you get started, put some fingernail polish on one set so there is no mistake next time.
Bruce
