sww914's Avatar
On small stuff that's really got it baked on, I start with oven cleaner, then diesel, then soapy water. The oven cleaner seems to really penetrate the hard gunk. On a big project I'll start with the oven cleaner and a putty knife, and then I'll take the whole mess to my friend's shop who has a giant dishwasher type of a parts cleaner. It does a really good job, but he charges me $20.00 to plug it in to heat it up, and it's 15 miles away, so I only do that when it's really worth the effort. Wear gloves like those playtex gloves that your mom used to wear.
Old 03-15-2008, 10:07 AM
Nitrometano's Avatar
Originally Posted by 911pcars View Post
As in dumping into the ground? Uhhhhh, no.
Pour back into original containers and take to the recycling center. No harm, no foul.... water.
Sherwood
yeah that is better. Dont try to flush the diesel via the toilet.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 03-16-2008, 10:07 AM
Is oven cleaner ok to use on aluminum or just steel?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-16-2008, 12:49 PM
sww914's Avatar
I've used it on aluminum, steel, magnesium, and fiberglass. I wasn't ever looking for a concourse finish, just looking to remove all of the gunk, so If you're looking for perfection I'd recommend that you test a small area first. I didn't notice any changes in color, but I wasn't looking for it. I was looking for gray metal instead of black crust. It gets spray paint off of fiberglass engine shrouds better than the new environmentally friendly paint stripper, that's for sure.
Old 03-16-2008, 01:01 PM
I took my engine cases to a local transmission shop and he put them in the cabinet that he uses to clean transmission cases (most are aluminum). He charged me $10 to clean the case ($20 for two). He did a great job for cheap. I use two cheap bead blasters to clean other stuff. One has glass beads as the medium and the other one has crushed walnut shells. The walnut shells are not nearly as abrasive as the glass beads and do not leave a rough surface on aluminum.
Tom
Old 03-22-2008, 06:00 PM
peppy's Avatar
I have not started cleaning my 3.2, but I was assuming that kerosene would do the job.
I do put in some ATF to make it a little easier on the hands, also cuts down on flash rust.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 03-22-2008, 06:23 PM
iangray100's Avatar
When I had my engine apart I jet washed the cases, on the hard encrusted bits I used paint stripper to loosen it and then jet washed it again , and repeated the process until it was clean and then for the internal parts etc. and the final wash on the cases I used diesel in the parts washing.
hope this helps
____________________
UK Surrey
Coupe 964 MY92 Tiptronic
To many toys to list..wife might be reading this ;-)
Personal thread: http://forums.pelicanparts.com/911-engine-rebuilding-forum/340187-964-3-6-full-engine-rebuild-over-uk.html
Old 03-23-2008, 03:40 PM
jluetjen's Avatar
Mineral Spirits. Doesn't corrode. Cuts the oil and varnish. Doesn't turn the gunk into cement.
Mineral Spirits.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-31-2008, 05:45 PM
Less brakes, more gas!
euro911sc's Avatar
Mineral Spirits.
+1/2 ... 'odorless' mineral spirits
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-31-2008, 06:29 PM
3 restos WIP = psycho
kenikh's Avatar
Don't do what I did...trusting the douche at Shuck's and using a water based degreaser. That sh--tuff cases aluminum parts to "fur up" in the blink of an eye. Thank goodness I have a soda blaster. YECH. Mineral spirits are a great idea!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-18-2008, 02:22 PM
Here's my case and cam towers back from the soda blasters:
andy
Old 07-20-2008, 11:28 PM
I tried to find a dry ice blasting service near here.. northern CA - no luck anyone know of one?
Old 07-25-2008, 07:35 AM
Possibly a stupid question but does mineral spirits go by any other name? Is this the same thing as paint brush cleaner? Is there a chemical name I can look for on the can to see if what I have is the same thing?
TIA
Buck
'88 Coupe, '87 Cab,
Old 07-25-2008, 11:23 AM
Paint thinner, turpentine, white spirit.
http://en.wikipedia.org/wiki/Mineral_spirits
Old 07-25-2008, 12:46 PM
