3 restos WIP = psycho
Imagine Auto Re-Releases Billet Valve Covers - 6speedonline.com Forums Although beautiful, they are flashy. The RothSport units are IMHO, kinda ugly, to boot.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Kenik,
I'd concur with Jeff A; billet items do not necessarily translate to a high-dollar investment however,........in some cases, the price reflects the number of hours invested in engineering, prototypes, materials, and the volume. When it comes to manufacturing, things are not always as simple as it might appear. ![]() The Rothsport ones are prototypes and do not necessarily reflect the final product. Further, these will be designed to assure that the coils cannot fall off the plugs under racing conditions on the top as well as the bottom.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Lindy911... do you have a number to contact said "Sam" ? Might be worth it to just have him weld some studs on for me. Making a bracket for the driver bank is going to be a pain. Some tight clearances there. For those that are curious... 89 Carrera with the factory 3.2L Have a clewitt engineering pulley with trigger wheel and sensor setup and distributor hole block off. Using OEM beru COP units with custom made harness. (Had to get the clips and rubber boots from a guy in NewYork that dealt with OEM porsche items in Germany) -that was a pain in the @$$ Using Megasquirt with MSnSE to try and run a EDIS type firing sequence. (two at once) Driving the coils with 6 BIP coil drivers mounted top side of the case. I had finally dialed in the signal from the trigger wheel and was starting to test the coils when the ign switch and relay under the seat went on me. Got tired of dealing Porsche wiring and lack of diagrams, so we opted to re-wire the ignition. This was about late July, then August University took over my life as well as work. Haven't really gotten to touch the project since then. With recent promotion at work, much less "hands on involved" (management) and having to drop Differentials this semester has given me some time to try and get this car going again. -Ed
78 280z 95 S14 03 350z father owned 89 911 C2 looking for a pre 73 soon! |
If I would install them in the lower covers I would add a bracket for safety.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. Last edited by safe; 11-12-2009 at 06:46 AM.. |
yeah, it appears a bracket/support solution is definitely in my future.
Why not coil-near-plug with LS2's. There was a recent engine for sale that had this in a twin-plug format. The upper coils were mounted what look like a modified OEM GM LS bracket and the lowers were mounted directly to the engine tin. LS2 give you huge spark energy and are extremely cheap.
![]() ![]() FS: Ultimate 2.7L Hot Rod Motor (Price Reduced)
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Randy's motor is a beast - if he used them, I trust them. A great idea.
How much more power is a result of this set-up?
JPIII Early Boxster |
Zero would be my guess.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Super Moderator
I saw a nice setup on a 911 motor this year that came from Peter Dawes shop. Simple and lightweight.
have any pics of it by chance Chris??
I live for 911 tweaks... |
The price comes down to the number of units one expects to sell to amortize all of the development and prototyping. I have looked into making valve covers and the dead cost with our machinery is not much at all, but cost recovery for development is what adds to the price.Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Automotive Writer/DP
Since my build more options have become available. Chris Powell is now using a surprisingly available part to make a coil on plug.
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
Does anyone know where to find a list of coils that have 'drivers' built-in versus those that need it on-board the ignition control module or an external one like the Ford EDIS solution used by MegaSquirt?
I don't know about Motec, but many of the other available systems I've seen do not have a driver resident in the control module. Sure would be convenient to be able to use coils with it built in instead of having to mount an addt'l set of components.
Mark B '73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold) |
I get it - I have appreciable experience from my past life in building parts in SolidWorks, multi-axis CNC machinery, investment (among other types of) casting and a full gamut of maufacturing and materials science expertise, as well. I also get the amortization stuff - I have done tons of COGS and ROI analysis, which is why I look at some of the products out there and just say WTF.
It seems so many solutions are solving problems with a 1 ton air hammer, when a handlheld hammer would do, for much less effort and investment. CNC machined valve covers to me seem like the 1 ton hammer, self retaining COPs like the Denso units (even with bent metal retiner brackets for the bottom bank) the handheld hammer. |
I agree with you 100%. For this application, I think a self retaining coil or a simple bracket is the best solution, not doubt.
But if one is offerring billet covers in their product line it make sense to have them suitable for COP as well. Plus, if a customer needs to replace their existing warped covers anyways, they may step up and buy a product like this over the factory stuff, assuming it is priced appropriately........ Cheers
Certified User
What coil packs are you using (part number?) and where did you source the connectors?
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
6, Coils: 06B 905 115R (R was the latest version at the time) 6, connectors (empty): 4B0 973 724 12, female spade connector pig-tails: 000 979 133 A 24, wire sealing grommets: 357 972 741 A 6, two-part plastic boots for connectors: 6X0 971 921 A Everything can be bought from your local VW/Audi dealer.
Puny Bird
My passat is really my wifes (mom's taxi) and sees at least 30,000km/yr.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
