304065's Avatar
Coil-On-Plug for Aircooled Engines?
Does anyone have experience with, or photos of, coil-on-plug setups for the 911-based aircooled engine?
I know the water-cooled cars use these, I wonder whether they are suitable for use next to the high temperature cylinder heads of a 911. Often times you see direct ignition with coil packs and short wires running to Beru-type connectors.
I have checked the websites of most of the shops and haven't seen anything for sale which is why I am curious.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-06-2008, 08:23 AM
Herr Professor Von Cramer,
We are working on custom valve covers for these cars to accomodate a C-O-P ignition setup.
We have done some of these using Motec Engine Management that works out just fine but the main issue is securing the ignition modules to the upper & lower valve covers properly.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-06-2008, 09:10 AM
304065's Avatar
Dr. Ing. Steve,
I was hoping you would chime in. . . I think our man Peter Dawe has done something like this as well. . . hard to find photos out there.
It looks like the Boxster uses a Beru coil with a separate connector to the plug. I wonder what the distance from seated on the plug to the surface of the cover is. . . could one weld a couple studs to the aluminum cover to hold the coil? Hmmm. . . .
I cannot seem to find a good picture of the 996 valve cover design. Tony (911quest) can you help, I know you tore a boxster engine down.
'81 R65
Old 06-06-2008, 02:20 PM
Slippery Slope Victim
NY65912's Avatar
Hi John,
When Bill and I were disussing my build he mentioned that he had done a few and if I were interested. He knew that I like a very clean uncluttered engine bay.
I said no.
Mike˛
1985 M491
Old 06-06-2008, 03:18 PM
Insane Dutchman
I am going to do it, I hate spark plug wires, distributors, advance curves, rotors, condensers and all that crap.
I was planning on just modifying the existing valve covers (drill out the holes, put in studs and go from there), but Dr. Steve's stuff may be interesting.
I also have to plug my distributor hole, I have seen Clewett's solution, don't like it all that much and was wondering if a press in aluminium disc with a couple of small retaining screws, all loctited and/or staked in, would look better and still be dry.
My only reservation is that Motec is expensive, but maybe they will make a stripper version for us street guys....
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 06-06-2008, 03:29 PM
Dennis
They do make a "cheap" version that is VERY good: M48, but it doesn't have sufficient outputs for C-O-P ignitions. One needs M600 to do this and that one is not cheap.
When it comes to Engine Management, you get just what you pay for,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-06-2008, 04:51 PM
Navin Johnson
TimT's Avatar
When I built the latest iteration of my motor a few year ago I was all set to do cop ignition, but my funds dried up... so I put a quick waste fire setup together.
I think the coils were almost $100 ea then.. I couldn't swing $1200 for coils then.
Bill and I were talking the other day, and we are going to do COP on his monsters powerplant... Also Dawe has a few out there running COP
'69 911 GT-5
'75 914 GT-3
and others
Old 06-06-2008, 05:09 PM
I believe Musante Motorsports and Rudtners are among the few who have attempted this with success. I have only good things to say about both of them, and I personally own a car that was converted to EFI by Bill Rudtner.
Old 06-06-2008, 05:31 PM
Forced Induction Junkie
WERK I's Avatar
I was going through the Jeg's catalog the other the other day, thinking the same thing. Maybe there are U.S. COP that are lower cost? I know the Ford DOHC engines have a pretty deep recess for the spark plugs similar to Porsches.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-08-2008, 08:10 AM
John - try this site for dimensions of the module - looks like type PT
Ignition coils at Bosch Motorsport
Regards
John
Old 06-09-2008, 03:57 PM
304065's Avatar
That is a nice dimensioned drawing that I can use to see where the coil would sit on the valve cover-- thanks.
http://www.bosch-motorsport.de/pdf/components/ignition_coils/Single_PT.pdf
'81 R65
Old 06-09-2008, 04:12 PM
sorry to bump an old thread, but I currently have 6 beru coils wired up to a 3.2L motor that I'm trying to get running with Megasquirt. I was curious if anybody has made progress with modifying the valve covers? I was going to make a bracket, but the valve cover idea sounds like a cleaner solution.
Thanks,
-Ed
78 280z
95 S14
03 350z
father owned 89 911 C2
looking for a pre 73 soon!
Old 11-09-2009, 07:21 PM
While the coilover setup is desireable I find the Crane CDI unit to be the best solution when considering cost vs performance.
Old 11-10-2009, 03:21 AM
3 restos WIP = psycho
kenikh's Avatar
there are several threads on this. some have used zx7 cops or audi cops effectively on 911 motors using an ems .
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-10-2009, 08:50 AM
safe's Avatar
I'm using the Audi/VW coil-on-plug. I drove at least 4000 miles this summer, both street and track, with coils from the scrapyard. No problems at al.
Magnus
Old 11-10-2009, 01:34 PM
rsscotty's Avatar
COP Valve cover
This is a new setup developed by Rothsport in Oregon. You can call Jeff Gamroth for details. 503 885 9626
Old 11-10-2009, 05:47 PM
kenikh's Avatar
Seems to me it would be cheaper to just fabricate an adapter ficture for existing valve covers that bolt to the existing fasteners. Billet = BIG BUCKS.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-10-2009, 05:57 PM
Jeff Alton's Avatar
Billet does not need to equal big bucks for something as simple as a valve cover. With the right equipment valve covers can be made pretty inexpensively....
Cheers
www.turn3autosport.com
Old 11-10-2009, 09:01 PM
I was just over at Pro Technik in Houston and they have a 3.2 based race motor that uses Motech EFI and Toyota Tundra COP. This is a single plug motor running 10.5 :1 compression making 325 RWHP! They just welded a stud to the valve cover and bolted the coil to it. Very clean! Call Sam and he'll share the details.
Old 11-11-2009, 05:41 AM
safe's Avatar
I don't use any extra fasteners... Haven't fallen of yet.
But the Rothsport solution is beautiful!
Magnus
Old 11-11-2009, 06:45 AM
