Engine rebuild after failure, check piston squirters
Rebuilding engine after PO has rebuilt after #6 damage.
Exact issue unknown but suspect rod bearing failure originally. Found this in one of the piston squirters, stuck partially open Might have been why PO gave up on engine as it was said to have piston slap. It had many more issues, but I'm sure this didn't help. Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
Is that silicone or plastic?
Member 911 Anonymous
What a nightmare
can this be done without splitting the case ?
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner |
The tubes i think but the squirtter heads themselves require splitting.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Ok thank you. Is there anything to do with them when case is still together? Maybe insert something pliable yet soft to confirm it's at least not clogged at the tip?
Under the radar
If that was in a squirter, what other debris is in the rest of the motor?
I believe the first failure must have been #6 rod bearing -- as the case has signs of damage where a connecting rod hammered the bore. That work had been fixed -- and the PO had the engine rebuilt. Shortly after that rebuild -- he had it torn down claiming it was piston slapping, but over the past few years of getting ready to rebuild this engine again we found numerous problems. The piston squirters were the last thing that we had looked at prior to reassembly and I'm glad my mechanic tested each or we might not have noticed the oil squirter issues. 6 new ones going in today. Mike
Still here
Scottsdale Arizona USA
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design +1 (844) URO-PART // modepw@europartswest.com |
