txhokie4life's Avatar
Engine rebuild after failure, check piston squirters
Rebuilding engine after PO has rebuilt after #6 damage.
Exact issue unknown but suspect rod bearing failure originally.
Found this in one of the piston squirters, stuck partially open
Might have been why PO gave up on engine as it was said to have piston slap.
It had many more issues, but I'm sure this didn't help.
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 03-25-2017, 10:35 AM
Is that silicone or plastic?
Old 03-26-2017, 06:46 AM
Member 911 Anonymous
DRACO A5OG's Avatar
What a nightmare
Old 03-26-2017, 02:14 PM
Tori's Avatar
can this be done without splitting the case ?
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 04-01-2017, 11:39 PM
DRACO A5OG's Avatar
The tubes i think but the squirtter heads themselves require splitting.
'85 Carrera Targa
PCA/POC
Old 04-02-2017, 10:23 AM
No, the case has to be split.
Old 04-02-2017, 01:14 PM
Tori's Avatar
Ok thank you. Is there anything to do with them when case is still together? Maybe insert something pliable yet soft to confirm it's at least not clogged at the tip?
Old 04-02-2017, 07:56 PM
Under the radar
Trackrash's Avatar
If that was in a squirter, what other debris is in the rest of the motor?
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-05-2017, 07:16 PM
I think I acquired this after the second tear down.
I believe the first failure must have been #6 rod bearing -- as the case
has signs of damage where a connecting rod hammered the bore.
That work had been fixed -- and the PO had the engine rebuilt.
Shortly after that rebuild -- he had it torn down claiming it was piston slapping,
but over the past few years of getting ready to rebuild this engine again
we found numerous problems.
The piston squirters were the last thing that we had looked at prior to reassembly
and I'm glad my mechanic tested each or we might not have noticed the oil squirter issues.
6 new ones going in today.
Mike
2001 996 GT2
Old 04-06-2017, 11:22 AM
Still here
pmax's Avatar
Originally Posted by txhokie4life View Post
Nice pic but any chance of getting some pictures of the case and the affected area ?
Old 04-06-2017, 12:15 PM
Scottsdale Arizona USA
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // modepw@europartswest.com
Old 04-13-2017, 01:05 PM
