Chain Tensioners
Can anyone tell me if you can you can apply the Carrera chain tensioner upgrade to a pre 69' chain case?
If yes is there a method of locating the oil line hole?
thanks All!
Panzer
Old 07-01-2008, 07:42 AM
304065's Avatar
You can, but it requires welding a boss on the aluminum cover. If you are going to use non-original tensioners, it doesn't make sense to use the original chain box-- the newer ones have more studs and better sealing and work with the Carrera tensioner covers.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-01-2008, 08:06 AM
3 restos WIP = psycho
kenikh's Avatar
Or you can do what I did: abandon pressure fed tensioners for 930 tensioner with collars. Depends on if you want it to look original or not.
If you go with pressure fed and dump your covers, I would love to take them off of your hands.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-01-2008, 10:12 AM
I will go with the pressure fed tensioners; originality is not of importance.
I have the newer style, which I will get prepared for the Carrera upgrade
I kind of blew it sending in the older ones to Ollies thinking it was an easy conversion and found out it might be more difficult when George gave me a look yesterday.
Anyway the pre-69 aluminum chain housings will become available when I pick up all my engine pieces. They have already been cleaned and media tumbled so they look great.
Thank you for the support guys.
Dave
Old 07-01-2008, 12:22 PM
which year 930 tensioners? and/or, does anyone have a part number? I'm preparing to do this in a couple of weeks on my 71T and I want to make sure I use the correct tensioner.
FWIW, I'm going to do the Jerry Woods mod in addition, as many on this board have suggested as a fail safe instead of the collars.
1985 redslope 930, 8:39 RP, S cams, B&B dual out muffler, IA Fuel Dist. Sitting on shelf awaiting installation: IA HF turbo, GSF headers(no heat), 46mm wastegate.
1971 911T Targa. needs alot of work(understatement).
Old 07-01-2008, 06:33 PM
Do you have to modify anything else? I've was advised that on the 68 you have to modify the cam.
Old 07-02-2008, 09:12 PM
