River Rat
Dave 86 930 Fl's Avatar
1st engine drop
I'm removing the engine from my 86 930 for the 1st time and I have a question regarding the removal of the large (steel braided) oil line that goes from the left (driver) side of the engine to the oil thermostat. Both ends are fairly obstructed, but it appears that the connection to the thermostat is somewhat more accessible. I'd appreciate any advice from those of you that have accomplished a drop of a turbo motor.
I've included a few pictures and you can see that the connection to the motor is very difficult to get access to without removing the exhaust first. Whereas, the connection to the thermostat is (more better) accessible.
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 09-16-2008, 07:38 PM
Back when I did this on my 88 3.2 I cleaned up the connections and used PB Blaster on them for a few days. I may have used a propane torch as well. Large wrenches are your friend here and I think Pelican even sells specific ones for the job but I did not need them. I was a little surprised it was not harder to remove than it was but the PB Blaster may have had something to do with that.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-16-2008, 07:45 PM
