philipp79's Avatar
jet settings on 2,2s weber conversion
Hi,
I am a new member with 1968 911 from Bavaria/Germany.
The engine is rebuilt to 2.2 s specifications and weber ida carbs. The ignition system is set up correctly and all wires are new.
Now I am looking for a recommendation for the correct jet settings. Can anybody help?
Thanks a lot and best regards
Philipp
Old 09-15-2008, 02:40 AM
philipp79's Avatar
some more details:
displacement: 2.2 l
compression: 1 : 10.5
911 S Camshafts
standard exhaust
standart air filter housing with K&N air cleaner
standard single plug CDI ignition from 1970 911S
manifolds: 35mm (cylinders site / 40mm carb site)
altitude: 300m above sea level
car will be used for road use
Old 09-15-2008, 05:06 AM
304065's Avatar
Phillipp,
Wilkommen auf der Forum.
Here is a thread to get you started, if you click on "search" you will find many more.
Richard Parr at PMO published the original guide to fitting Weber 40s to a 2,2S. It is here in the archives.
40 mm Weber Carb Settings
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-15-2008, 06:28 AM
