Max Sluiter
Flieger's Avatar
Is this an MFI engine or carburetors?
This also is a Rally kit engine, I wonder if there were differences between cars used in rally and circuit races.
Old 10-04-2008, 10:57 AM
BURN-BROS's Avatar
Originally Posted by CanuckRS View Post
Aaron,
Do you have this type of document for the other ST motors we are discussing ??
If so, can you post them...
Does anyone know what type of work the factory may have done on these cases ??
TIA
Sorry, I do not.
However, The sheet posted is the formula porsche used on most of the racing engines. Diffences would have been induction and rod material.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-04-2008, 11:51 AM
Yzerman-45's Avatar
Hi there! I am thinking of building my self an ST replica up here in cold Norway. (crazy??maybe...)
Anyway.. All the ST had carburetors, and i think theres was 40 IDA,s with some "slight" modifications.
My car (a 1965 912 originally) has an 2,7 with 40 IDA,s.
Old 10-15-2008, 07:10 AM
CanuckRS's Avatar
To the best of my knowledge, all the ST motors had either MFI or Weber 46mm IDAs...
Peter
#23 911 T/R Inspired Vintage Racer - Retired
2010 VW Touareg V6 TDI Torque Monster...
2010 Radical SR3RS - CSR Sports Racer...
"Don't Drive faster than your Guardian Angel can Fly..."
Old 10-15-2008, 07:34 AM
BURN-BROS's Avatar
Correct, either hi-butterfly MFI or the 46's were the "normal" specs for this motor type.
Burnham Performance
Old 10-15-2008, 09:41 AM
Max Sluiter
Flieger's Avatar
There were some MFI engines as well.
Do you know "Fredrick 911" who made a DVD at the Nuerburgring Nordschlieffe with a 911ST? He also got the urge to build an ST replica. Not easy in Norway...
Old 10-15-2008, 12:44 PM
Yzerman-45's Avatar
I knew that there wher 46 IDA.s, i just pressed the wrong buttons... )
I did not knew that there where some ST,s with MFI,s. Are you sure??
Fredrik is my "brother in law" (i am not married to, but live together with his sister!)
Fredrik and me are also best friends with Christer,( "Mr." raceunivers.com) who is also part of the Nürburgringfilm.I will advice all you "petrolheads" like me to visit Christer,s site! www. raceunivers.com
All of you with PRE 73, are also welcome to join our PRE 73 forum: http://porschepre73.ning.com/
Old 10-16-2008, 02:03 AM
