Max Sluiter
Is this an MFI engine or carburetors?
This also is a Rally kit engine, I wonder if there were differences between cars used in rally and circuit races.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
However, The sheet posted is the formula porsche used on most of the racing engines. Diffences would have been induction and rod material.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
![]() Anyway.. All the ST had carburetors, and i think theres was 40 IDA,s with some "slight" modifications. My car (a 1965 912 originally) has an 2,7 with 40 IDA,s.
To the best of my knowledge, all the ST motors had either MFI or Weber 46mm IDAs...
Peter #23 911 T/R Inspired Vintage Racer - Retired 2010 VW Touareg V6 TDI Torque Monster... ![]() 2010 Radical SR3RS - CSR Sports Racer... ![]() "Don't Drive faster than your Guardian Angel can Fly..." |
Correct, either hi-butterfly MFI or the 46's were the "normal" specs for this motor type.
Max Sluiter
Do you know "Fredrick 911" who made a DVD at the Nuerburgring Nordschlieffe with a 911ST? He also got the urge to build an ST replica. Not easy in Norway...
I knew that there wher 46 IDA.s, i just pressed the wrong buttons...
)I did not knew that there where some ST,s with MFI,s. Are you sure?? Fredrik is my "brother in law" (i am not married to, but live together with his sister!) Fredrik and me are also best friends with Christer,( "Mr." raceunivers.com) who is also part of the Nürburgringfilm.I will advice all you "petrolheads" like me to visit Christer,s site! www. raceunivers.com All of you with PRE 73, are also welcome to join our PRE 73 forum: http://porschepre73.ning.com/ Last edited by Yzerman-45; 10-16-2008 at 06:04 AM.. |
