Super Moderator
cstreit's Avatar
2.5L options
(repost from tech forum, meant to post here)
Hey guys,
Was talking with someone the other day about Porsche race engines for vintage cars and we got on the topic of the 2.5L engine. I know there were a number of different options for this engine but I couldn't remember what all the different combos were out there.
Can anyone give me the "typical" 2.5L's?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-10-2008, 07:22 AM
I would rather be driving
jpnovak's Avatar
THere are two types of 2.5L motors. The first is an overbore of a 2.0 or 2.2. This uses 90mm bore x 66mm crank. These have excellent rod/crank ratios and can easily be used at high rpm with the right oil mods.
The second is an overbore of a 2.4L. This uses 86.5(?)mm bore x 70.4mm crank. These are not as common as the Short stroke version.
Old 12-10-2008, 07:27 AM
Warren Hall Student
Bobboloo's Avatar
The short stroke 2.5 is a great combo since it's so easy to make. Start with a 2.7 7R case motor and then swap out the crank and rods from a 66mm motor. Add P+C of your choice! Voila!
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 12-10-2008, 08:37 AM
89 x 66 is another possible combo.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 12-10-2008, 08:58 AM
Super Moderator
cstreit's Avatar
THanks guys. What are the relative specs on these engines? ('Reasonably' acheivable HP/Tq)
Chris
1996 993 RS Replica
Alcon Brake Kits
Maybe 250 hp? A factory 89 x 66 race engine with 10.3:1 was 275@8000 rpm (courtesy of bruce's wonderful handbook).
Charles Navarro
Old 12-10-2008, 09:03 AM
3 restos WIP = psycho
kenikh's Avatar
It is pretty much top end specific. A nice port job to around 38mm w/ MFI or EFI and GE60 (I prefer DC62) cams should easily be good for 100HP/L at 7800 RPM.
I went this route with a 2.3L and should have impressions in early Spring.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-10-2008, 10:27 AM
2.5
We have built some full house long stroke engines for HSR and have made over 300 @ the FW, range is 5500 - 8000 RPM, short stroke about the same numbers but HSR has mandated an RPM rule and passes out MSD chips to 8200.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-10-2008, 02:33 PM
Plavan's Avatar
Here is the Dyno for my 2.5L short stroke at the rear wheels. GE80 cams, Stock 2.7 valves, opened up ports, CW crank, 2.2L rods, true 10.5:1- Almost 100 hours now and coming out for a refresh- 2.5L #2 is ready to take its spot
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 12-11-2008, 07:59 PM
I Also have a few questions. I have a 72T euro motor that I would like to build a 2.5 with. Can I just bore my iron cylinders? Is there any pistons that will work with the iron T cylinders? I think there iron anyway....
Old 12-13-2008, 06:24 AM
The T iron cylinders can be bored out, but reliably, really no more than to 85mm. Plus, if you do end up making the horsepower that is expected, the T cylinders don't have the needed cooling capacity.
Charles Navarro
Old 12-13-2008, 06:40 AM
kenikh's Avatar
255 crank HP - nice!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-13-2008, 10:38 PM
I'm guessing one would need MFI, carbs or EFI to make a 2,5SS perform?
I was thinking of making my 175hp 2,7 into a SS, but I'd rather not part with the CIS.
/Nimskov
Old 12-14-2008, 12:31 AM
120 HP/Liter is all I ask
A nice street 2.5 can be had by using the Mahle high compression 90 mm 2.7 RS kit (if it is still available) with a 66 mm crank. Nominally 10.4:1 compression with a 70.4 mm crank, this kit makes 2518 cc and around 9.5:1 CR with the 66 mm crank.
Old 12-16-2008, 09:01 AM
