Super Moderator
2.5L options
(repost from tech forum, meant to post here)
Hey guys, Was talking with someone the other day about Porsche race engines for vintage cars and we got on the topic of the 2.5L engine. I know there were a number of different options for this engine but I couldn't remember what all the different combos were out there. Can anyone give me the "typical" 2.5L's?
I would rather be driving
THere are two types of 2.5L motors. The first is an overbore of a 2.0 or 2.2. This uses 90mm bore x 66mm crank. These have excellent rod/crank ratios and can easily be used at high rpm with the right oil mods.
The second is an overbore of a 2.4L. This uses 86.5(?)mm bore x 70.4mm crank. These are not as common as the Short stroke version.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Warren Hall Student
The short stroke 2.5 is a great combo since it's so easy to make. Start with a 2.7 7R case motor and then swap out the crank and rods from a 66mm motor. Add P+C of your choice! Voila!
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
89 x 66 is another possible combo.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Super Moderator
THanks guys. What are the relative specs on these engines? ('Reasonably' acheivable HP/Tq)
Maybe 250 hp? A factory 89 x 66 race engine with 10.3:1 was 275@8000 rpm (courtesy of bruce's wonderful handbook).
3 restos WIP = psycho
It is pretty much top end specific. A nice port job to around 38mm w/ MFI or EFI and GE60 (I prefer DC62) cams should easily be good for 100HP/L at 7800 RPM.
I went this route with a 2.3L and should have impressions in early Spring.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
2.5
We have built some full house long stroke engines for HSR and have made over 300 @ the FW, range is 5500 - 8000 RPM, short stroke about the same numbers but HSR has mandated an RPM rule and passes out MSD chips to 8200.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Here is the Dyno for my 2.5L short stroke at the rear wheels. GE80 cams, Stock 2.7 valves, opened up ports, CW crank, 2.2L rods, true 10.5:1- Almost 100 hours now and coming out for a refresh- 2.5L #2 is ready to take its spot
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 12-11-2008 at 08:03 PM.. |
I Also have a few questions. I have a 72T euro motor that I would like to build a 2.5 with. Can I just bore my iron cylinders? Is there any pistons that will work with the iron T cylinders? I think there iron anyway....
Thanks |
The T iron cylinders can be bored out, but reliably, really no more than to 85mm. Plus, if you do end up making the horsepower that is expected, the T cylinders don't have the needed cooling capacity.
255 crank HP - nice!
I'm guessing one would need MFI, carbs or EFI to make a 2,5SS perform?
I was thinking of making my 175hp 2,7 into a SS, but I'd rather not part with the CIS.
/Nimskov |
120 HP/Liter is all I ask
A nice street 2.5 can be had by using the Mahle high compression 90 mm 2.7 RS kit (if it is still available) with a 66 mm crank. Nominally 10.4:1 compression with a 70.4 mm crank, this kit makes 2518 cc and around 9.5:1 CR with the 66 mm crank.
