Chain fence eating turbo
Average cost of rebuilding heads?
I am going to have to replace the guides, 6 exhaust valves, and possibly the springs (overrev).
How many hours does it take a shop roughly and how much?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-07-2009, 05:11 PM
Cory,
Prices vary quite a bit but IMHO, the question you should basking is "who can do a competent and proper job of it?".
In these situations, quality is much more important than price.
Some shops are all set up to resurface, machine the seats, R&R the guides/hone to fit everything on 911 heads; others are better equipped for other types of engines.
Call me if I can help.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-07-2009, 05:30 PM
Originally Posted by Steve@Rennsport View Post
Cory,
Thanks Steve,
The shop I went to today I feel is very competent. The owner wanted to take about 6-8 hours to put in guides, hone, dress seats, and check springs heights/pressures.
Add in the cost of parts and I calculating around $1500 in my head. That is a little more than I anticipated.
I was trying to get a consensus of what these cost should be.
Old 01-07-2009, 05:39 PM
Czar of C.R.A.P.
dfink's Avatar
For that money they should be twin plugged. The last couple of sets I had done were around $600.00
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 01-07-2009, 07:01 PM
Less brakes, more gas!
euro911sc's Avatar
$1200 for mine. Full machine on the seats to stock and mating surface clean 0.010". Everything assembled, cleaned, and ready to put on the engine. I picked them up, so shipping was not included. The company was Extreme Cylinder Heads here in FL. Great rep and Bill is on here, infrequently, but on here. He has some amazing heads he engineered and manf. for bigger engines RACE PORN!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 01-07-2009, 07:31 PM
That sounds more like it, thanks.
-Michael
Will look into, thanks. I like RACE PORN...
Old 01-07-2009, 08:04 PM
andrew15's Avatar
It depends what your definition of 'rebuilt' is.
Just new valves, guides, springs, and valve guide seals cost over $650
Add in labour to:
- clean, strip, and inspect heads
- surface the mating surfaces
- replace guides
- cut seats
- shim springs to correct height
- vacuum test valve seating
- maybe install a few timecerts on the exhaust stud tappings
I think a complete overhaul is going to be closer to $1,200 than $600.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 01-07-2009, 09:40 PM
304065's Avatar
Call Bob at Anchor Atlantic Enterprises
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-08-2009, 06:50 AM
+1
Bob is a good guy to work with.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 01-08-2009, 07:11 AM
Add in labour to:
- replace guides
- cut seats
Regards,
Andrew M
I gotcha, just used to American heads getting rebuilt for about $2-300.....
Will take note of, thanks!
Old 01-08-2009, 12:03 PM
dtw dtw is offline
GAFB
EBS did a set of 2.7 heads for my last year. Off the top of my head:
-12 new valves
-12 new springs
-12 new guides
-install guides
-valve grind
-fly-cut heads
-etc etc.
I think it was around $1,100.
Several BMWs
Old 01-08-2009, 12:21 PM
-12 new valves
-12 new springs
-12 new guides
-install guides
-valve grind
-fly-cut heads
-etc etc.
Thats a lot of work and more closer to what I would expect, thanks!
Old 01-08-2009, 04:47 PM
I just priced a set of SC heads here in Chas, SC at a very good machine shop. Price is approx $450 plus guides and seals.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 01-11-2009, 08:41 PM
Jeff Alton's Avatar
I pay 600 flat rate (cdn) to have the heads disassemble, inspected, new guides, valve grind, sealing surface machined, bead blasted and reassembled. Extras would be any new valves required and the cost of twin plugging (300) if one desired.
This is the machinest the dealer and all the local independents use. I have head probably 8-10 sets done with excellent results.
It all boils down to hours X dollars plus parts. Assuming your machinest is knowledgable. The only variables should be labor rate......
Cheers
www.turn3autosport.com
Old 01-11-2009, 09:31 PM
3 restos WIP = psycho
kenikh's Avatar
Cheers
Jeff, what's is name? I'll be back in Vancouver in a few week.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-11-2009, 09:36 PM
Jeff Alton's Avatar
Lance Hayward, www.haywardperformance.com tell him i sent you!
Lance is an excellent machinest, does great work including case repair.
Give me a shout when you are up here.
cheers
Old 01-11-2009, 11:15 PM
Certified Pre-Owned
BGCarrera32's Avatar
I would contact "cgarr" a user on this forum. He does head work and twin plugging out of his home shop. His prices are very good and the pictures of his work I have seen look excellent. He did my rockers and is a good guy to deal with. I know he has done several heads for guys on this forum. He is in Michigan.
Since I am changing out and upgrading everything I opted for EBS in Nevada. I doubt there are too many shops that do as much of this as they do.
'84 Carrera Coupe
Old 01-12-2009, 07:25 AM
kenikh's Avatar
cheers
Ah yes, my brain is finally out of neutral - Bob Magyar told me about Lance as well and had only great things to say.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-12-2009, 09:19 AM
Cynical Misanthrope
AFM744's Avatar
Send a message via Yahoo to AFM744
From German Precision in Sunnyvale:http://www.germanprecisioninc.com
Remove, replace, bore new Exhaust guides
Cut all 12 seats
Grind 12 valves
Grind 12 rockers
Twin-Plug
New valve seals
Intake port bore to 38mm
inspected rocker shafts, rod small and big ends, a few other things
~$1,400
Ted was a great guy to work with.
X-1, AFM744, Jon, '92 C2 Turbo
JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending...
Where my misspent time and money is currently going.
Old 01-12-2009, 09:48 AM
Registered?
blee's Avatar
Kenik - Any possibility you can take my heads too?
Brian
R Gruppe #757
70T Ex-Waterlogged Rust Bucket
http://forums.pelicanparts.com/porsche-911-technical-forum/519605-waterlogged-rust-bucket.html
Old 01-12-2009, 10:05 AM
