Brother's Avatar
Clarifying the dream 3.0 build
I'm starting to narrow the field of potential cars to buy. I'm really closing in on 78-79 SC's. I would like to get the car and do some bolt on mods and then eventually do a rebuild for the final push. The goal would be to make a 10lbs/hp car.
Starting with a large port 3.0
Bolt ons - PMO's (40 or 46's?) or ITB EFI
SSI's
M&K muffler
Mods for engine rebuild:
98mm pistons and cylinders
Twin Plug
12 plug dizzy
Tranny cooler
cams (unsure of grind)
Questions:
Am I out to lunch with my wish to get around 250-270 hp with good low to mid range torque?
Is there a better or more common accepted solution for this problem?
Are there any problems that I need to pay attention to or look out for?
Is there really any benefit to the big port heads on the early SC's?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 05-23-2009, 10:45 PM
Brother's Avatar
bump for the long weekend.
Paul
1972 914 - Sold
Old 05-27-2009, 09:06 AM
Corrupted by power
SSI's
M&K muffler
Twin Plug
12 plug dizzy
Tranny cooler
Questions:
You aren't out of line at all. A short stroke 3.2 should be able to get there without issues with the right cam choice.
Good read:
What is the Best Cam for this Set up?
Question to all those who have a 3.2L Short Stroke W/46mm PMOs??
First Dyno Run
Wanna build a ss 3.2?
These should answer most of your questions.
Old 05-27-2009, 09:32 AM
